Engine air filters.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jun 19, 2023.
  1. Jun 21, 2023 at 8:03 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    All filter material as they get dirty (plug up) will trap more & smaller debris. Now, the air/fuel ratio will be less air flow.
  2. Jun 21, 2023 at 8:06 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I'm sorry, that is incorrect. A dirty air filter has exactly zero impact on the air/fuel ratio.
    BillyE and D.A.S. Taco like this.
  3. Jun 21, 2023 at 8:08 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Problem with K&N filters is, some come with excessive oiling, they will foul your trucks MAF sensor. I had to clean mine in the tundra several times till enough dirt covered that air cleaner fabric. They really made no difference in performance till I did a dual flowmaster exhaust system including using their flowmaster cats.
  4. Jun 21, 2023 at 8:18 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I am well aware of the impact of over oiling the K&N filters on the MAF. Just don't be a douche nozzle and over oil them and you will be fine. The one in my FJ has almost 200K miles of air through it with zero issues with the MAF / engine. But like with anything in life, your mileage may vary!
    Carry on!
    D.A.S. Taco likes this.
  5. Jun 21, 2023 at 8:23 AM
    zoo truck
    None
    I understand over oiling after you wash the filter out once it hits 50k miles, but this was a brand new in the box filter that kept setting the ecl off. I kept finding a flim of oil inside the MAF sensor that needed to be washed out.
  6. Jun 21, 2023 at 8:35 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    If there is an oil residue down stream of the filter, the filter had too much oil applied. Could be from the maker or owner.
  7. Jun 21, 2023 at 8:49 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I have a Volant "Drytech" cone filter. Volant's instructions say the filter is good if you can see the wire mesh. I'm at 27k miles and can still see the wire mesh through the clear air box lid.
  8. Jun 21, 2023 at 8:56 AM
    Tacospike
    Two Trucks
    Check it every few months while I have the hood up. Makes sense since I'm already there and takes 10-15 seconds.
    probably change every 10-12k and replace the cabin filter same time
  9. Jun 21, 2023 at 9:08 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Thanks for sharing, I noticed my truck would engine brake more with (in my case) the foam pre-filtered ACDelco but I didn't think it would affect performance like that. I guess thats the kinda thing you'll mostly notice under load when the engine wants all the air it can swallow. I guess it comes down to filtration vs efficiency
  10. Jun 21, 2023 at 9:10 AM
    Vmax540
    Chuck
    Clarion PA.
    https://www.bing.com/search?pc=CBHS...&q=does+a+dirty+air+filter+affect+gas+mileage
    Yes
    According to 8 sources
    Yes, a dirty or clogged engine air filter can affect gas mileage by reducing the airflow to the engine, which can cause the engine to work harder and use more fuel to maintain performance.
    Does Air Filter Affect Gas M…
    harristirecompany.com
    If the air filter is dirty, it passes less air into the engine. That is not a good thing. It can impact your gas mileage – by as much as 10 % – and it will also affect engine performance.
    TheDanimal, bullpen58 and RedWings44 like this.
  11. Jun 21, 2023 at 9:17 AM
    Horseshoez
    Dale
    Maryland
    Sorry, total b.s., if you want to provide good information, please choose a good source: http://www.fueleconomy.gov/feg/pdfs/Air_Filter_Effects_02_26_2009.pdf
  12. Jun 21, 2023 at 9:25 AM
    joba27n
    Nolan
    Alberta
    Just to be clear as they're both being interchanged. A dirty air filter will negatively impact fuel economy. It does not change the air fuel ratio. Just chokes the engine essentially. It'll still use the same air fuel ratios based on throttle input, load, etc
  13. Jun 21, 2023 at 9:30 AM
    Horseshoez
    Dale
    Maryland
    Once again, incorrect. Read the exhaustive study by Oak Ridge National Laboratory (I posted the link above); you will discover fuel economy will not be negatively impacted unless you drive a vehicle with an old-school carburetor.
    joba27n[QUOTED] and Starman2112 like this.
  14. Jun 21, 2023 at 9:47 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I've found 10-15k is usually acceptable for the conditions I drive in. Also lines up w/ the blackstone results I've received on oil w/ about 10k miles and state filtration seemed good.
  15. Jun 21, 2023 at 9:54 AM
    #35
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
  16. Jun 21, 2023 at 9:55 AM
    #36
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    well,,, we found a new hot button
    Junkhead and joba27n like this.
  17. Jun 21, 2023 at 11:03 AM
    #37
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    At least the argument isn’t “what brand of oil used on the filter?”
    Chew[QUOTED] likes this.
  18. Jun 21, 2023 at 1:07 PM
    #38
    Two4Runner
    Two4Runner Well-Known Member
    LD
    Shreveport
    2017 DCSB TRD Offroad 4x4
    Where are y'all getting engine air filters? Walmart (Fram) and a couple of local parts houses have none. What is a good website for oem filters? ....maybe I just need to go to dealer.
  19. Jun 21, 2023 at 1:43 PM
    #39
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Wix is what I prefer
    Locally or RockAuto
  20. Jun 21, 2023 at 1:49 PM
    #40
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
