Engine Air Filters
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trigger1013, May 16, 2024.
  1. May 16, 2024 at 6:13 PM
    Trigger1013
    Trigger1013 [OP] Member
    North east Georgia
    2017 TRD sporty
    No mods… yet. On TW to listen to some experienced fellers who can help me do it right.
    Hey yall new member here just got a 2017 TRD sport tacoma the other day and I know that one of the first things on YouTube and such that everyone should get is a new engine air filter. The most common being the TRD brand and of course K&N. Now I don’t want a new airbox because I like the stock design of them just the square filter itself. The main reason I want to get one of the two (TRD or K&N) is because they can be cleaned and reused unlike the stock one. Can anyone provide experience or facts on the matter on witch one is better.
  2. May 16, 2024 at 6:27 PM
    JackieDaytona
    JackieDaytona Well-Known Member
    2016 inferno sr5
    In progress
    Trigger1013[OP] likes this.
  3. May 16, 2024 at 6:42 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    If you drive dirt/dusty roads, stick to paper.
    If only streets, trd or whatever fits.
    Buy 2 and rotate them
  4. May 16, 2024 at 6:48 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    I’d just use the paper filter OEM Toyota air filter only. What’s the big deal, only have to replace it every 30k miles or so
    Barsoom, jmneill, NC Gazzer and 6 others like this.
  5. May 16, 2024 at 6:53 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    best bet!
    No need to over engineer this one.
    Add to that, the time to clean, dry, and lube doesn't save me any money, as my time is worth more than the filter.
    musicisevil, Barsoom, jmneill and 4 others like this.
  6. May 16, 2024 at 6:59 PM
    sac119
    sac119 Well-Known Member
    IL
    2020 MGM TRDOR DCSB 4x4
    I run K&N in my 3rd gen and did in my 2nd gen all without issue. The key is to lightly spray the filter with the oil after you clean it. I had a professional mechanic tell me that people overspray them with the oil and it will cause your engine to throw codes.
    TN1000 and Trigger1013[OP] like this.
  7. May 16, 2024 at 7:05 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Just use this:
    Available at Walmart $15. Don't use K&N, they let dirt in & are a pain in the butt to clean properly.
  8. May 16, 2024 at 7:13 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    Get a high quality paper air filter from your local auto parts store.
    I would highly recommend against an oiled filter unless you intend to wash it and re-oil it religiously every 45-60 days. Which nobody does.
    It is also quite likely the oil you spray (which will be too much) on the filter can and will foul your Mass Air Flow sensor, and throttle body assembly, which is another reason to avoid oiled filters.
    musicisevil, maineah, TN1000 and 2 others like this.
  9. May 16, 2024 at 8:20 PM
    Trigger1013
    North east Georgia
    2017 TRD sporty
    Understood. That’s a smart idea to keep two and swap
    Robnik likes this.
  10. May 16, 2024 at 8:21 PM
    Trigger1013
    North east Georgia
    2017 TRD sporty
    Good point it is a lot easier and quicker to unlatch the box and throw in a new one
    Chew[QUOTED] and Robnik like this.
  11. May 16, 2024 at 8:22 PM
    Trigger1013
    North east Georgia
    2017 TRD sporty
    Yeah I sure as hell don’t want to piss off any electronics or sensors as this is my first truck with the modern technology
    Robnik likes this.
  12. May 16, 2024 at 8:23 PM
    Trigger1013
    North east Georgia
    2017 TRD sporty
    How many miles/years you got using these?
    Robnik[QUOTED] likes this.
  13. May 16, 2024 at 8:25 PM
    Trigger1013
    North east Georgia
    2017 TRD sporty
    Alrighty then well I’m glad I went to TW to come ask yall what yall do. Seems like it’s just a bunch hooey for someone to accidentally do something to their truck.
    RustyGreen, Chew and Robnik like this.
  14. May 16, 2024 at 8:27 PM
    Robnik
    Rob
    Greenacres, Florida
    I'd change it every 20,000 miles depending on where you live & drive. I use OEM, think I've changed mine twice in 12 years. Wasn't even dirty. :)
  15. May 16, 2024 at 8:40 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    might be better to read the manual instead of youtube for maintenance of your vehicle.....the paper filter works best and cheaper
    BoomerGVNG and ridefreak like this.
  16. May 16, 2024 at 8:57 PM
    Vlady
    Issy, WA
    Nothing wrong
    Nothing wrong with "oil filters". Use common sense. We used to drive Soviet pos with oil bath filters in the desert. Car rusted 1st.
    PTSDTherapy and faawrenchbndr like this.
  17. May 16, 2024 at 9:44 PM
    StreetSr5
    StreetSr5 Well-Known Member
    I’m running dry synthetic k&n, $50 never have to worry about buying an air filter again and don’t have to worry about over oiling.
  18. May 16, 2024 at 9:53 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I used to run the FRAM ones, but it bugged me seeing the orange sticking out the side of the intake box lol.
    OEM isn't that much more, so I just pick one of those up when I go by the dealer now.
  19. May 16, 2024 at 10:01 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    bmorgan1022 likes this.
  20. May 17, 2024 at 3:07 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Take a look at the AFE pro s dry filter…….no oil issues and it’s washable
    dand and Trigger1013[OP] like this.
