Engine Air Filters
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trigger1013, May 16, 2024.
  1. May 17, 2024 at 4:06 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The 3.5 Tacoma and 5.7 Tundra use the same air filter element.
    If it flows well enough for the big V8 any "restriction" of a quality OEM dry style filter shouldn't hamper the performance of the V6.
  2. May 17, 2024 at 4:50 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    Hey all , is there a need to ever change your PCV valve out when you change your air filter?
    Also what is everyone's thoughts on installing an oil catch can?
  3. May 17, 2024 at 9:47 AM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    THAT right there.
  4. May 17, 2024 at 1:36 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    The PCV (positive crankcase ventilation) valve is, generally, what most people treat as a "run to fail" component. Once they fail (clog up with carbon) however, this scenario may result in oil leaks because the crankcase has no way for the internal pressure to relieve. So there is a slight downside potential to that approach.
    If I were you, I would remove yours and inspect it. Give it a spritz of brake cleaner followed by a spritz of spray lube. Shake it and blow through it. It is really nothing more than a simple one-way check valve. If that works for you, re-install and check it again yearly going forward.
    Alternatively, buy a new one for $30 or so and slap it in there. And forget about it for the next 50k miles.
    As far as catch cans go, I'm not an advocate. (Nor am necessarily against them). In my personal case, my Taco doesn't "burn" or consume any oil between oil changes. Like zero. None. Like not even 1 mm on the dipstick. So that leads me to believe the amount of oil vapors that would condense and be caught in a catch can would be infinitessimal. Just not worth it. Others may have different experiences and suggestions. One positive thing about a catch can, unlike some other dumb mods people make, is that it literally cannot cause any harm.
    YMMV and I hope everyone has a great weekend. It is FRIDAY!
    Barsoom likes this.
  5. May 17, 2024 at 2:24 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I did a catch can, mainly because I was bored and couldn't think of anything else to do to my truck at the time. It does trap some oil, a few ounces every 1k miles or so. Probably not enough to show on the dipstick, but not zero either. Will it make a difference? Probably not. But you probably don't need to change your PCV valve with every air filter change.
  6. May 18, 2024 at 8:20 AM
    Cadha13
    Cadha13 初音ミク #1 Fan, and Bacon Wrapped Hot Dog Cook
    David
    Albuquerque
    2022 TRD OR DCSB 6MT
    OEM Bed Lights
    I just think that there's a TRD oiled air filter means that Toyota thinks it's OK for a while. I put in a K&N a few months ago.
    In the Old Days they used oil bath air cleaners, paper air filters didn't exist, but those engines were worn out by 30k miles.
    Just follow the maintenance intervals to what filter system you're using, and you'll be fine.
  7. May 18, 2024 at 1:19 PM
    Redsquirrel
    Redsquirrel Well-Known Member
    this is what i have
  8. May 19, 2024 at 3:48 AM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Change my air and cabin filters each April fools day for good measure. I hardly ever get them dirty.
    23MGM likes this.
  9. May 19, 2024 at 7:30 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    the PCV valve is an important inexpensive part. at less than $20, i see no need to clean and re-use it. i would suggest changing it at the same time the spark plugs are changed, which according to toyota should be about every 60K miles.
    i do not have any experience with a catch can and can't comment.
