Engine and Dash Vibration on Acceleration
Discussion in 'Technical Chat' started by SoonerRobin, Nov 28, 2011.
  1. Nov 28, 2011 at 9:21 PM
    SoonerRobin
    SoonerRobin [OP] New Member
    Robin
    Shawnee, Oklahoma
    PreRunner SR5
    Kenwood Head Unit, Westin Bull Bar and Platinum Nerfs.
    I have an 05 Double Cab w/extended bed that is experiencing harsh vibrations through the steering wheel and dash under acceleration. When I let up on the gas the vibration stops. I changed out my spark plugs and that certainly helped, but the vibration is still there. I have checked my tires and have them balanced and rotated every 3K. I am running premium gas through it and using a fuel injector cleaner which seems to help but the vibrations are still present. I tried the ODM II scanner and I just get the "8888" error message. I'm thinking it could be a transient failure in a coil pack, but not sure how to check it without a good scan. I have also read about this model having a weak rear engine mount, and the sealed carrier bearing or universal could be worn. I need a clever idea on how to diagnose this problem. Also, I suspect a bad pulley because I sometimes get a high frequency noise on deceleration from 70 MPH.
  2. Dec 1, 2011 at 9:42 AM
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    Could be a laundry list of things!
    Take it to a shop if you cant diagnose it yourself, no one online will be able to diag it either, only recommend other laundry lists of issues. Try seaching. If it were a coil pack you'd be mis firing like crazy and CEL will be flashing.
    Its most likely a busted/worn motor mount, or an issue with the driveshaft.
  3. May 21, 2012 at 1:02 PM
    SoonerRobin
    Robin
    Shawnee, Oklahoma
    PreRunner SR5
    I took her into a local transmission shop and and the front and back U-Joints needed to be replaced. Got her back and she runs great! Thanks for the feed back.
