Engine Bay Cleaning. Hot or Cold?
Discussion in 'Detailing' started by Kelson, Sep 8, 2011.
Engine Bay Cleaning
  1. Engine Hot (Running)
    7.8%
  2. Engine Warm (Not Running)
    25.8%
  3. Engine Cold
    46.1%
  4. Dolphins!
    20.3%
  1. Sep 21, 2011 at 6:04 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I like Simple Green, good bang for the buck. If it's very nasty, Castrol Super clean is the way to go. It is very agressive stuff, though. Don't get it on your hands.
  2. Sep 24, 2011 at 2:57 PM
    Tacoma mud
    Tacoma mud Well-Known Member
    Kyle
    TEXAS
    97' xtra cab sr5 4x4
    soon to come
    Deffinately cold... Some are flammable and if your engine catches on fire itll be blacker than before!
  3. Apr 19, 2012 at 9:46 AM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I like to get the engine so hot that it glows red ... :eek: ... then dump a barrel of ice cold water on it and watch it fizzz ... :eek: ... :D
  4. Apr 19, 2012 at 1:08 PM
    JaimeSR5
    JaimeSR5 Well-Known Member
    Jaime
    Fontana
    03 PreRunner-4Banger
    K&N filter,-JDM tailights, NGK Spark Plugs, 6k H.I.D head light kit, fog light kit
    do it while the engine is cold, use a steam pressure washer to wash down all the engine cleaner, once your done make sure you dont have any exposed wiring...turn your engine on to dry it up faster once your done..
  5. Apr 20, 2012 at 7:47 AM
    sabre19
    sabre19 Member
    Phoenix, AZ
    2011 i4 Auto SR5 4x4
    GROM-USB2 w/ iPod and BT interface, OEM hitch and trailer harness, OEM tube steps, AFE Pro Dry S
    I clean my engine bay when the engine is cold. After I'm done, I start it up, let it idle for a few, then take it for a short hop on the interstate to dry it out. Just for a little added insurance, I cover up the front diff breather tubes and the alternator before hosing everything down.
  6. Apr 20, 2012 at 8:30 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  7. Apr 20, 2012 at 9:16 AM
    aw113sgte
    aw113sgte Well-Known Member
    Hot or cold....both are fine.
    I've dunked a hot engine in a water crossing many times, never an issue. Granted it does cause more stress but it's unlikely to hurt anything.
  8. Apr 20, 2012 at 12:14 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
  9. Apr 24, 2012 at 6:18 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) When I clean any of my engine compartments, i go to the spray wand type of car wash and use the engine cleaner at the car wash. I enter the stall, cut off my engine and pull the hood release. I open the hood to let it cool a bit and I get my change. I spray down the whole compartment with sprayer on engine cleaner and then let it sit for a minute or two, then I use the pressure wand on clear water and I clean off the engine cleaner. I do not cover anything and I spray the whole area. No problems doing this to the engine. Then I clean the rest of the vehicle and leave.
  10. May 9, 2012 at 8:42 AM
    Dezrat
    Dezrat Active Member
    Poway
    99 Taco PreRunner v6
    Deck plate mod,HID 10k, 4 Piaa 40 series, front/ rear Tube bumpers, alpine system.
    When I clean my engine bay I tend to wrap my alternator in a plastic bag then I'll spray the engine with a bottle of degreaser, I avoid spraying directly to some electrical connections. I leave my engine cold personally but it's up to you. Then I'll power wash it. It looks pretty diecent in the end and never had any problems. Good luck guys!
  11. May 9, 2012 at 8:51 AM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    I don't think it matters.
  12. May 9, 2012 at 1:20 PM
    Madjik_Man
    Colorado Front Range
    Just spray it down with Simple Green. Let it sit for a few minutes.
    Hosed it off.
    Made absolutely no discernible difference. Still looks dirty and grimy.
    Any suggestions?
  13. May 9, 2012 at 1:48 PM
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    I've detailed my engine both after driving it and first thing in the morning when it's cold....honestly no difference.
    What makes the difference are the products and tools you use.
    I like to DOUSE the motor, sometimes I use half a brand new bottle with my favorite engine degreaser:
    Let it sit for about 15-20 mins. Do not water the motor before. Just spray it directly on when the motor is dry.
    Rinse it all off(a pressure washer would be IDEAL) and let it air dry or use an air compressor. Repeat the steps in the super greasy/dirty areas.
    To finish it off, I use this stuff and apply it pretty generously:
    Here is my engine after taking the steps and using the products I mentioned above:
    Goodluck!
  14. May 9, 2012 at 1:51 PM
    STiLL WILL
    CA
    I used to use Simple Green, it works on the dirt, but not so much on the greasy spots. Pick up a bottle of Purple Power Citrus degreaser. Best stuff I've used, and it's as "safe" as Simple Green. I use it to degrease underbodies all the time and it just kills it all off.
  15. May 9, 2012 at 5:07 PM
    #35
    Madjik_Man
    Any issues with staining or etching aluminum?
  16. May 9, 2012 at 5:27 PM
    #36
    STiLL WILL
    CA
    With the CITRUS CLEANER Purple Power, I had zero etching issues.
    The Industrial Strength Purple Power cleaner/degreaser(white bottle) is a different story. I will never use that stuff again on polished aluminum. Very bad etching. They advertise it as "non-abrasive" but don't let that fool you. It's definitely strong stuff. Etching is proof.
  17. May 9, 2012 at 6:06 PM
    #37
    Madjik_Man
    thanks for the heads up
  18. May 10, 2012 at 2:56 AM
    #38
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    I had a buddy who always sprayed the entire engine bay with armor all and then hose it down. His engine bay always looked great and he swore it never bothered anything. IDK if I'd do it, but it's another option I guess. Personally I never hose or power wash the engine. I go at the rubber with a rag soaked in quick detailer and just a wet rag to wipe down the rest.
    But, I don't go mudding
  19. May 10, 2012 at 3:08 AM
    #39
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    It is always hot by the time I get to the car wash. I try to lightly mist it to get everything wet and started cooling before I shock it with lots of water. If you are going to crack something, throwing lots of water quickly on it would be the way to do it. I figure easing into it is the best way.
  20. May 10, 2012 at 4:29 AM
    #40
    CantSitStill
    FTR
    CNY
    DAMN! If that isn't a testament to your method working, I don't know what is! Looks GREEEEEEEEEEEEEEEEAT!
