Engine block and Trans codes/numbers??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HAWAIICALIVEGAZ, Jan 16, 2012.
  1. Jan 16, 2012 at 6:51 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ [OP] Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    Is there a list or spreadsheet Where I can find the different engine and trans codes for tacomas, 4runners and tundras? Maybe even their according HP/tq numbers as well? Also where is it stamped/located on the block?
    I posted this in the performance section as well but wasn't really getting any responses.. Maybe you guys can help?
    ok did a little research and this is what I came up with...
    Tacoma
    First generation (1995–2004)
    2.4 L 2RZ-FE I4 142 hp (106 kW) and 160 lb·ft (217 N·m) of torque
    2.7 L 3RZ-FE I4 150 hp (112 kW) and 177 lb·ft (240 N·m) of torque
    3.4 L 5VZ-FE V6 190 hp (142 kW) and 220 lb·ft (298 N·m) of torque.
    The 3.4 V6's manual transmission was an R150F while the automatic transmission was an A340F (Aisin code is 30-40LE).
    Second generation (2005–present)
    2.7 L 2TR-FE I4 (159 hp) and 180 lb·ft (244 N·m). of torque.
    4.0 L 1GR-FE V6 (236 hp) and 266 lb·ft (361 N·m) of torque.
    (1GR-FE) engine has a supercharger from (Underdog Racing Development). Increasing RWHP from 209 to 425. 236 horsepower (176 kW) to 470 horsepower (350 kW). The OEM for this supercharger is Rotrex)
    4Runner
    First generation (1984–1989)
    2.4 L 22R I4 (1984–1986)
    2.4 L 22R-E I4 (1985–1989)
    22R-TE I4 (1986–1988)
    3.0 L 3VZ-E V6 (1988–1989)
    2.4 L 2L I4 (1984–1989)
    2.4 L 2L-T
    turbodiesel I4 (1985–1989)
    2.0 L 3Y I4 (1984–1989)
    Second generation (1989–1995)
    2.0 L 3Y I4
    2.4 L 22R-E
    3.0 L 3VZ-E
    2.4 L 2L-TE turbodiesel I4
    2.8 L 3L diesel I4
    3.0 L 1KZ-T turbodiesel I4
    3.0 L 1KZ-TE turbodiesel I4
    Third generation (1995–2002)
    2.7 L 3RZ-FE I4
    3.4 L 5VZ-FE V6
    Fourth generation (2002–2009)
    4.0 L 1GR-FE V6
    4.7 L 2UZ-FE V8
    3.0 L 1KZ-TE I4 turbodiesel (Latin America)
    3.0 L 1KD-FTV I4
    Fifth generation (2009–present)
    2.7 L 2TR-FE I4 (157 hp, 2WD, 2010 only)
    4.0 L 1GR-FE V6 (270 hp) (4.0-liter V6 adds Dual VVT-i)
    Tundra
    First generation (2000–2006)
    3.4 L 5VZ-FE V6 190 horsepower (2000-2004)
    4.0 L 1GR-FE V6 236 horsepower (2005-2006)
    4.7 L 2UZ-FE V8
    245 horsepower (2000-2004)
    282 horsepower (2005)
    271 horsepower (2006)
    Second generation (2007–present)
    4.0 L 1GR-FE V6 (VVT-i) 236 horsepower
    4.7 L 2UZ-FE V8 (VVT-i) 276 horsepower
    4.6 L 1UR-FE V8 (VVT-i) 310 horsepower
    5.7 L 3UR-FE V8 (Dual VVT-i) 381 horsepower
  2. Jan 17, 2012 at 6:48 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    edit: everything posted in the first post
