Engine Block Heater Need?
Discussion in 'Alaska' started by 07tacomagirl, Jun 29, 2011.
  1. Jun 29, 2011 at 12:17 PM
    07tacomagirl
    07tacomagirl [OP] New Member
    Anchorage, AK
    07 Tacoma TRD
    Hey Alaskan Tacoma owners! I'm going to be moving to Anchorage at the end of the year, and was wondering if there is any need to install an engine block heater. I plan to find a place with a garage, but that's not a guarantee. Thanks for the advice.
  2. Jun 29, 2011 at 12:25 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Welcome to TW! The block heater probably isn't a bad idea and the factory one is a very simple install. There is a port on the backside of the engine block that the factory block heater screws into.
  3. Jun 30, 2011 at 3:51 PM
    Scott78
    Scott78 Well-Known Member
    Scott
    Vacaville, CA
    '13 STI Hatch\\
    Consider an oil heater as well or first if you're worried about your engine lasting. The block heater is nice but not a necessity in Anchorage, farther north sure. It doesn't really do much good for your oil though and when it's cold and thick is when you're engine is going to suffer. Coolant doesn't lubricate your engine, and cold thick oil doesn't do much better. I ran both on my previous taco and will install both again on this new one I have before winter.
  4. Jun 30, 2011 at 4:02 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Welcome! I live up in northern Canada :woot: :canada:
    I use my block heater up here throughout the winter, but truth be told, with synthetic in the engine, I've seen it start with zero issues in -20, colder then that I usually plugged it in
  5. Nov 2, 2011 at 11:41 PM
    sg4506
    sg4506 Member
    Andrew
    Anchorage
    '11 TRD offroad
    3" RevTek lift, Poweraid throttle body spacer, K&N Aircharger, 8000k Headlights and foglights, 2" aluminum wheel spacers
    Go over to Kendal Toyota on 6th and Gambel and ask them about the "Fairbanks package" it's a block heater, oil pan heater, and battery heater. Absolutely worth it. Truck warms up in 3 minutes in the dead of winter and starts up really easy.
  6. Nov 3, 2011 at 2:33 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    A block heater in Anchorage really isn't necessary. I never had one on my previous vehicles and they start fine in the cold, just be sure to let it properly warm up before driving away. I have a battery warmer, and that helps a bit. But I would switch to synthetic oil and call it good. I'm planning on doing that my next oil change.
  7. Nov 14, 2011 at 9:32 AM
    BearB8
    BearB8 Ex-Texan, found a bigger state
    Handsome
    Bonner Ferry, ID
    '15 DCSB TRD Off-Road
    If you are merely worried about being able to start in the morning just switch to 0-20W synthetic and you won't have a problem. If you are more concerned about longevity and wear and tear than still switch to synthetic and add a block heater/oil pan heater. I think you can get a block heater from Kendall for under $40 and the install is super easy (don't let the dealership charge you $400 plus for the Fairbanks package). I am in ANC once a month and I can help with the install if you need.
  8. Nov 18, 2011 at 7:43 AM
    07tacomagirl
    Anchorage, AK
    07 Tacoma TRD
    I already run synthetic oil, and luckily found a place with a heated garage. I will be coming up in the middle of December, so hopefully the first couple of weeks will go well! Thanks for all the advice. I am looking to do some work on my Tacoma (probably a leveling kit or short lift and new wheels/tires), so any suggestions are appreciated.
  9. Nov 18, 2011 at 4:29 PM
    ffirg
    mike
    Anchorage, Alaska
    Nice! A heated garage is all you need. It was -6 today when I started my truck up and it does just fine. Turns over kind of slow, but it starts every time. I hope you have driven in the snow/ice before :D
