Engine block heater question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nazlax10, Oct 31, 2016.
  1. Oct 31, 2016 at 1:24 PM
    nazlax10
    nazlax10 [OP] Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    So I'm moving to Anchorage in February. I bought an engine block heater and an oil pan heater. My question is is it possible to splice the two together into one plug? This way I have one plug up front and only have to plug it in for both components. Thanks for any input. Here is a drawing that I'm sure a 5 year old could've done better to "help" out.tw.jpg
  2. Oct 31, 2016 at 4:33 PM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
  3. Oct 31, 2016 at 4:39 PM
    nazlax10
    David
    Woodstock, GA
  4. Oct 31, 2016 at 4:56 PM
    Voodoo Rufus
    Bakersfield, CA
    You could seal it up using some dielectric grease. For good measure there should probably be a circuit breaker or fuse in there somewhere.
