Engine block
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Red rocketsr5, Jan 26, 2018.
Should I run 110
  1. Yes
    27.3%
  2. No
    72.7%
  1. Jan 26, 2018 at 10:15 PM
    Red rocketsr5
    Red rocketsr5 [OP] New Member
    2005 red Tacoma sr5 prerunner
    I have a 2005 Toyota Tacoma prerunner and I was wanting to run 110 racing fuel in it . Iean it's v6 4.0 but is it forged or milled
  2. Jan 26, 2018 at 10:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Waste of money.
    inwood customs likes this.
  3. Jan 26, 2018 at 10:24 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Is the engine race built for a 15:1 compression ratio?
  4. Jan 26, 2018 at 10:26 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
  5. Jan 27, 2018 at 3:37 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Good Lord
  6. Jan 27, 2018 at 7:07 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  7. Jan 27, 2018 at 7:11 AM
    scocar
    scocar Patron of the Farts
    Based on the details you've provided so far, I'd have to say
    Definitely plaid.
    balljoint likes this.
  8. Jan 27, 2018 at 7:46 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I run moonshine in winter months.:goingcrazy:
  9. Jan 27, 2018 at 8:20 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    You’ll gain about 250hp and over 300tq. That truck is gonna scream. Can’t believe no one else has tried this yet, I mean it’s such a good idea.
    4drtaco03 and Sprig like this.
  10. Jan 27, 2018 at 8:43 AM
    Sharpish
    Brian
    Unless you are running a ton of boost or the engine is race built with a crazy high compression ratio, 110 octane is a waste of money. It won't make the truck faster.
    Higher octane=less explosive. On a race engine lower octane gas wil pre-ignite and ping.
    scocar likes this.
  11. Jan 27, 2018 at 9:37 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    You may as well do it right and go with top fuel nitromethane. I think you’ll be surprised at the results. I’d suggest the first time you do this you do so about 100 miles away from all human habitation. Let us know how it works out.
    Red rocketsr5[OP], b_r_o and Torspd like this.
  12. Jan 27, 2018 at 10:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Be Green. Go Hydrazine!
    Red rocketsr5[OP] and Sprig like this.
  13. Jan 27, 2018 at 1:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try putting vape juice in it
  14. Jan 27, 2018 at 4:59 PM
    Dens71TA
    Dens71TA Well-Known Member
    2014 SR5 ACLB 4x4 2.7L A4
    Make sure you get the 110 octane with lead. It cleans out the catalytic converters ...
  15. Jan 27, 2018 at 8:46 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Why not go 111 octane?
  16. Jan 27, 2018 at 8:49 PM
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    :yes:
  17. Jan 27, 2018 at 8:51 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
  18. Jan 27, 2018 at 8:53 PM
    Whiteghost184
    Whiteghost184 Well-Known Member
    Florida
    2007 URD 4x4 DC LB
    2007 SR5 DBLB 4x4 G2 456 gears front and rear 6" Procomp stage 1 XD 20×10 Toyo 35x12.50x20 E-Load Pioneer head unit Alpine amp running all the door speakers Backflip bed cover Fender Flares URD Stage 1 and 2 Aftermarket seat covers Built Transmission including After market valve body IPT Torque Converter Trans Cooler and EPC Solenoid Full 2.5" URD exhaust and Headers (part of the stage 2 kit) 30" light bar mounted in front bumper Next: M1102 Camp Trailer Conversion
    Did you just trade in you Frontier?
