Engine blown at 71k
Discussion in '3rd Gen. Tacomas (2016-2023)' started by likxrokx, Mar 3, 2025.
  1. Mar 4, 2025 at 3:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Obviously I can't speak personally for them. But my referral came from a trust worthy friend who has used them for a long time. About as good as you can get from 1,100 miles away.
    Hope you can get it all squared away.
  2. Mar 4, 2025 at 7:17 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    That's the sixty-four-thousand dollar question; if you're capable of doing your own fab work, or if someone makes a plug and play kit, it is probably cheaper to drop an LS in there, if not, my gut tells me replacing your 3.5 will be the best option.
    Chew and CygnusX191 like this.
  3. Mar 4, 2025 at 7:43 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    You somewhat need to know what the cause was....
    Zero need to teardown the old engine though...
    But if a bad "stuck open" injector bent a connecting rod...
    You dont want to install a new engine with the same faulty injector as this will wipe-out the new engine...
    But the dealer knows this, hands down youre at the right place.....
    They know their product, they know what should be replaced along with the engine, etc....
    Theyre not just going to hack it back together & sed you down the road, regardless if it right or not, like your other tech did...
    joba27n and CygnusX191 like this.
  4. Mar 4, 2025 at 7:44 PM
    slater
    San Diego
    there was no reason to throw an injector at it, if it truly had a severe knock...
    Jerry311SD and CygnusX191 like this.
  5. Mar 4, 2025 at 8:09 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Lol, yeah OP paid someone to do the spark plugs I don't think an ls swap is in play. Especially for 11k.
    (Probably in play at 2x that price.)
  6. Mar 4, 2025 at 8:19 PM
    MGMDesertTaco
    CygnusX191 likes this.
  7. Mar 4, 2025 at 8:21 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    An LS swap would be amazing... but... emissions inspections...
    Nevermind the hassle of getting all the oem electronics to play nicely with an aftermarket ecu setup.
    Very sorry to hear of your troubles, OP.
  8. Mar 4, 2025 at 8:22 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    As long as the engine is newer than the frame, you shouldn't have an issue with emissions or verification
  9. Mar 4, 2025 at 8:22 PM
    MGMDesertTaco
    MagicToolbox, CygnusX191 and auskip07 like this.
  10. Mar 4, 2025 at 8:32 PM
    Toy_Runner
    99 4Runner SR5
    There's lots of older ls motors in junkyards that would be cheap to rebuild, but PA has to abide by cali's carb equivalent for emissions inspections, at least in my county. One county over from me and its just a safety inspection.
    I'm assuming you also mean you keep/use whatever oem ecu and header to cat exhaust setup for the emissions with a new(er) yesr engine swap.
    CygnusX191[QUOTED] likes this.
  11. Mar 4, 2025 at 9:39 PM
    trailmeisterjoe
    trailmeisterjoe Well-Known Member
    Joe
    Pacific Northwest USA
    2017 Tacoma SR5 2WD AC
    Have you had it since new, and if you have, how often was the oil changed?
    auskip07 and CygnusX191 like this.
  12. Mar 5, 2025 at 7:46 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    If you're still searching for shops there is an Ohio thread in the regional forums, you may want to post your problem there as well.
    Best wishes to you.
  13. Mar 6, 2025 at 1:55 PM
    likxrokx
    likxrokx [OP] Member
    Quick question for yall..
    What would be a decent amt to ask for a Toyota Tacoma 4×4 dbl cab sr5 71k mis, blown engine? (Long block situation)..
    It has Cooper tires, less than 2k on them, nice fabric tonneau cover, bed liner, bully bar on front, window louvers, weather tech mats, graphite gray, gray cloth interior. Interior is in excellent condition.. (I kept it covered, front and back, body has scratch on tailgate and 2 dings on drivers side.
    I have all the receipts for all the maintenance and upkeep, but I think at this point, that's not going to be important.
    Dealership offered to cut me a check for 7k.. I may be delusional, but I think that's a little low. It's why I'm asking here.
  14. Mar 6, 2025 at 2:08 PM
    BigTang
    BigTang Well-Known Member
    C
    2022 SR
    put it on market place for 15 and take 12.
    Tacosha, CygnusX191 and likxrokx[OP] like this.
  15. Mar 6, 2025 at 2:57 PM
    #35
    Clearwater Bill
    Billy
    Largo Florida
    Look at dealer retail and assume the engine was still good. Subtract 10k and what is the result?
  16. Mar 6, 2025 at 3:49 PM
    #36
    545
    545 Well-Known Member
    2015 Access Cab
    12k for a non running vehicle?
    Sucker born every minute I guess
    Barsoom and CygnusX191 like this.
  17. Mar 6, 2025 at 4:01 PM
    #37
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    300,000-400,000 miles on those engines is the norm. Having one die at 71,000 is either bad luck or bad maintenance. I'd find a scrapyard engine with 75,000-100,000 miles on it and have it put in. Not sure how that much would cost but a wild guess is under $5000. It should be good for many more years. Even if you decide not to keep the truck it's going to be a lot easier to sell and you'll come out better selling a working truck.
  18. Mar 6, 2025 at 4:28 PM
    #38
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    I was wondering maybe you could sell it part by part and get more money out of it instead of throwing it for 12K ish. You could place it on Copart , lots of flooded, dead engine cars etc there but selling it part by part might be better idea.
  19. Mar 6, 2025 at 4:29 PM
    #39
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    $4-5k is a good price on this route.
    And a lot cheaper than a new truck
  20. Mar 6, 2025 at 4:32 PM
    #40
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    just click on "start a conversation" under his name and avatar
