Engine Bog?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacosoup89, Nov 19, 2013.
  1. Nov 19, 2013 at 9:47 AM
    tacosoup89
    tacosoup89 [OP] Active Member
    Carrollton, Ga
    2003 2.7L PreRunner
    Ok so ive changed spark plugs, changed fuel filter and ive cleaned the MAF sensor and my engine still sucks ass. I don't know what else to do. The truck just doesn't have any power it seems and when you start from a stop it just kinda surges up to speed. So now Im wondering if its perhaps injectors or vacuum lines? Any ideas anybody?:confused:
  2. Nov 20, 2013 at 11:54 AM
    toastyjosh
    toastyjosh Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    Go check all of your vacume lines, if there is crack in some of them there may be a issue.
    Clean you throttle body, run some gas treatment through the tank, seafoam the truck.
    Then pull your EFI fuse to reset your ecu. If you still have issues report back
  3. Nov 20, 2013 at 12:07 PM
    02coma
    02coma Well-Known Member
    la puente
    02 dc
    Try to switch coil.
    If high miles check timing for jump
