Engine bogs down, rough vibration, no power
Discussion in 'Performance and Tuning' started by Jbuller5517, Sep 27, 2014.
  1. Sep 27, 2014 at 7:11 PM
    Jbuller5517
    Jbuller5517 [OP] Member
    Josh
    California
    07 prerunner xsp
    Hey everybody, I'm new to world forums. Just really hoping somebody could help me out. My truck recently started acting up. When I'm driving if I go to pass someone in the truck reaches about 4000 RPM' S the engine all of a sudden bogs down and then if you try to give it any gas it vibrates really hard and you have no power. It stops if I pull over turn off the truck and turn it back on it's just fine but each time it's revved up it does the same thing. If anybody could help me out I would appreciate it.
  2. Sep 27, 2014 at 7:25 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    do u have a K&N air filter?
  3. Sep 27, 2014 at 7:27 PM
    cevallos.j
    cevallos.j Well-Known Member
    Jorge
    Coronado
    2006 Prerunner access cab
    sounds like its misfiring, maybe check spark plugs/coils/wires.
  4. Sep 27, 2014 at 7:35 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    only happens under high demand huh?
    Curious if its our wonderful fuel pump
  5. Sep 27, 2014 at 9:35 PM
    Jbuller5517
    Josh
    California
    07 prerunner xsp
    No K & N air filter, but I was told previously could be the spark plugs coil overs or wires. But I'will have to check the fuel pump as well. Do you know about how much that runs?
  6. Sep 28, 2014 at 10:51 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Last time you did maintenance on your MAF?
  7. Sep 28, 2014 at 11:21 AM
    Jbuller5517
    Josh
    California
    07 prerunner xsp
    Actually haven't for quite awhile, I'll take a look at that as well
  8. Sep 28, 2014 at 11:41 AM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    Could be as simple as spark plugs. Try replacing them first. I had a misfire code on my old X-Runner and it ran rough under acceleration. It was just a bad plug.
  9. Sep 28, 2014 at 12:33 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No check engine light?
  10. Sep 28, 2014 at 1:46 PM
    Taco'09
    Taco'09 Well-Known Member
    ^^This.
    Anyway do the easy stuff first: plugs, MAF clean, and work your way uphill. Before you drop the tank and pull the pump (not a real fun job) see if someone can check fuel pressures (a special Toyota adapter is called for).
