Engine bolt removal question!
Discussion in 'Technical Chat' started by dustinclm, Jul 21, 2011.
  1. Jul 21, 2011 at 6:10 PM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    While frustratingly tightening the nuts on the EGR valve, i overtightened the nuts and one of the bolts sheared. However i managed to reattach the valve but now i heve some air leaks from the area. My question is, before i remove the valve again, how hard would it be to remove the bolts from the engine? Could i clamp a vice grip on the sucker and replace the bolt? or would it be so stuck in there that im screwed? Also, would the threads on the bolts be "opposite" so that i would have to turn to the right to loosen?
    thanks
  2. Jul 21, 2011 at 6:15 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    they should be normal. if you turned it right and it was left hand threads it would back out...
    if you cant get it out via vise grips you may need to drill it out and use an easy out to remove it
  3. Jul 21, 2011 at 6:22 PM
    dustinclm
    Thibodaux, La
    i know its pretty much impossible to say the bolts will come out easy but the space is pretty tight so getting a drill in there and being able to work it will be next to impossible and i dont have an easy out.
    Also, would anyone know if i could get the bolts at auto zone or would i have to go to toyota?
