Engine Braking - AT Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nl_tacoma, May 13, 2022.
  1. May 13, 2022 at 4:40 AM
    nl_tacoma
    nl_tacoma [OP] Well-Known Member
    Newfoundland
    2018 Tacoma TRD Sport DCLB
    I often have my AT transmission is S mode and down shift to help with braking. Every now and again the transmission will downshift when I apply the brakes. When I try to replicate the auto downshift I can't but it does happen at times when I'm not trying.
    Will the Tacoma AT transmission downshift in S mode on it's own or am I just applying the brake at the same time that the transmission is downshifting?
  2. May 13, 2022 at 4:52 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Man, you are really over thinking this. Just put it in drive and let your foot control the braking.
    musicisevil, Tac0Tic0 and bulalo like this.
  3. May 13, 2022 at 4:57 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    My 0.2 cents . Brake pads a lot cheaper to replace than transmission. I wouldn’t intentionally use the AT to help with braking
    musicisevil, Borracho Loco and knayrb like this.
  4. May 13, 2022 at 5:01 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I use the engine to brake all the time. Yes, there are times where I get an uncommanded downshift when braking and it catches me a little off guard. I believe there is a gyro in the truck since this only happens on a downgrade...and it also happens in D as well. The truck will not let the trans downshift past a redline situation and downshifting does not harm the transmission whatsoever to decelerate.
    nl_tacoma[OP] likes this.
  5. May 13, 2022 at 5:30 AM
    nl_tacoma
    Newfoundland
    Gotcha. Thanks. Lots of hills in my neck of the woods. Some are steep - especially going into the coastal areas or in the mountains north of me. Downshifting or engine braking helps. I'm not redlining the truck, just picking the right gear. 4, maybe 3 at times on the big hills.
    cropduster78 likes this.
  6. May 13, 2022 at 5:35 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I believe what you are experiencing is converter unlocking. Drive more worry less.
  7. May 13, 2022 at 6:18 AM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    What's an "AT transmission"?
  8. May 13, 2022 at 6:55 AM
    nl_tacoma
    Newfoundland
    Automatic
  9. May 13, 2022 at 7:16 AM
    E.J.
    Josh
    NWA
    I'm just feeling Friday and funning you. I read it as automatic transmission transmission, kind of like ATM machine or VIN number.
    I always assumed one of the main reasons for S mode is to facilitate engine breaking, I use it a lot for that to control my speed off-roading.
  10. May 13, 2022 at 7:17 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've noticed the transmission will automatically upshift to the next S mode gear if my engine exceeds a certain rpm.
    nl_tacoma[QUOTED][OP] likes this.
  11. May 13, 2022 at 7:18 AM
    cropduster78
    cropduster78 Well-Known Member
    NW CT
    '17 DCLB SR5 White
    OV-TUNE 2.0, ADDED/REMOVED STUFF
    S-mode is awesome it keeps these in the powerband nicely on hills.:thumbsup:
  12. May 13, 2022 at 7:19 AM
    zoo truck
    None
    ''All terrain'' transmission
  13. May 13, 2022 at 7:21 AM
    E.J.
    Josh
    NWA
    SWEET!
  14. May 13, 2022 at 7:34 AM
    nl_tacoma
    Newfoundland
    lol. nice one. i can see that now. it's good to laugh - even at my own expense.
    E.J.[QUOTED] likes this.
