Engine Braking vs Brake Pad Costs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kyle.t.monaghan, Sep 29, 2023.
  1. Sep 29, 2023 at 2:03 PM
    #41
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Agreed, in my younger and more reckless days i've frequently downshifted into the redline with no ill effects. even in my ranger which had 200'000kms and 5 years of reckless/abusive driving which included towing 3 times the weight of the truck(I would never do that again for alot of reasons) and, hauling 1/2 the trucks weight in the bed to name the worse. Also included was the engine being pulled and reinstalled to remedy all the leaks, transmission shearing the bell housing off (cleaned and reused the clutch because I was broke at the time and just out of college) and brake rotors cracking from an ill adjusted master cylinder. (all my fault and gave me alot of learning opportunities from apprentice to technician). Clutch was installed by me when I bought the truck and still had about 60% life when I measured it during the transmission replacement which was about 50'000kms before I got my Tacoma and also when I smartened up and matured out of being a deviant driver. Engine was unphased as far as running and driveability goes. Still pulled 20"hg at 251metres above sea level as it did when I bought it and still would pull 25"hg when you snap the throttle. If none of that killed my piston rings combined then i'm sure responsible downshifting would be alright. Oil change habits would probably have a bigger influence
    Horseshoez[QUOTED] likes this.
  2. Sep 29, 2023 at 2:49 PM
    #42
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Gravity is a beatch.
  3. Sep 29, 2023 at 6:02 PM
    #43
    Late Camaro
    Late Camaro Well-Known Member
    Central Ohio
    22 TRD Sport Barcelona Red Access Cab MT
    Brought it home 3-16-22
    With todays factory tunes, engine braking (with a manual, or an automatic) also shuts off/or nearly off the fuel supply - increased mpg’s. If you are planning to slow/stop the manual tranny vehicle, engine brake in the current gear until the rpm’s are roughly 1500, place the tranny in neutral, and brake as needed to safely stop or slow as needed. With the tranny in neutral, the engine will idle, using very little fuel, no wear is applied to the clutch, the brake wear is reduced. If there is another vehicle on your bumper, lightly apply the brakes to show the brake lights - safety first….
    Okkine 2.0 likes this.
  4. Sep 29, 2023 at 6:18 PM
    #44
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I drag an old tire when I have to drive on mountains
  5. Sep 29, 2023 at 6:21 PM
    #45
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Brake pads are cheap and easy to change lol
    This is a funny religious thing for some people though
    Chew likes this.
  6. Sep 29, 2023 at 6:23 PM
    #46
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    Similar to how the right lane can be faster than the left lane. Drive at a steady pace and end up passing the same cars driving in the left lane multiple times as they tailgate each other and have to slow down/speed back up.
    Tocamo[QUOTED] likes this.
  7. Sep 29, 2023 at 6:35 PM
    #47
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Ideally you want to limit the heat created by the brakes.
    In which case, Engine and Pads is the preferred method.
    Under normal circumstances, you don’t really need to use engine braking.
    If you’re creating that much heat in “normal” driving, something is wrong.
  8. Sep 29, 2023 at 6:36 PM
    #48
    Bishop84
    Bishop84 Well-Known Member
    I downshift as much as I need so I’m not on my brakes more than 20% of the grade. Ideally 10% or less.
    recently towed a small trailer down a hill and you are also trying to prevent brake fade on top of wear.
    ToyoTaco25, joba27n and TnShooter like this.
  9. Sep 29, 2023 at 7:26 PM
    #49
    Okkine 2.0
    Okkine 2.0 Well-Known Member
    2022 TRD Sport, Lunar Rock
    I removed those annoying stickers on the sun visor.
    Interestingly, I'm currently having this exact same argument on Facebook.
    I've always used engine braking as much as possible. It's easier on the brakes (especially in the mountains), allows for better control of the vehicle, and ensures you're in the right gear to rapidly accelerate if the need arises.
    I've only ever had to replace a clutch twice, both times on vehicles where the clutch was already worn out by the previous owner.
    If you're doing it properly, then there really shouldn't be any more wear and tear than regular driving.
    If you're constantly accelerating and decelerating with the clutch half engaged, you're going to wear it out fast.
    If you're matching the RPMs while shifting, it will last a long time.
  10. Sep 29, 2023 at 7:43 PM
    #50
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I looked on out of the window
    And I started countin' phone poles
    Going by at the rate of four to the seventh power
    Well, I put two and two together
    And added twelve and carried five
    Come up with twenty two thousand telephone poles an hour
    RustyGreen and RIX TUX[QUOTED] like this.
  11. Sep 30, 2023 at 8:03 AM
    #51
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    There are the people that drive with a foot also on the brake. Crazy to see with them gunning it up an incline while their brake lights are on.
    Chew and TnShooter[QUOTED] like this.
  12. Sep 30, 2023 at 8:24 AM
    #52
    Okkine 2.0
    My dad had an old Chrysler station wagon that would stall the moment you took your foot off the gas. Bought it brand new, and it was like that from day one. Nobody ever could figure it out.
    At red lights, you had to brake with your left foot, so that you could keep your right foot on the gas.
    40 years later, he still catches himself braking with his left foot sometimes.
  13. Sep 30, 2023 at 11:09 AM
    #53
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    That’s interesting.
    The 2 foot driving seems to get blamed for a lot of those accidents where people drive into store fronts when they mix up the brake and accelerator. lol
    Chew likes this.
  14. Sep 30, 2023 at 11:13 AM
    #54
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    :rofl:
  15. Sep 30, 2023 at 12:37 PM
    #55
    Okkine 2.0
    That doesn't surprise me at all!
  16. Oct 1, 2023 at 5:06 PM
    #56
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I got 100k out of my first set of brakes. The only time I actively use engine braking is in mountainous terrain with long downhills. This is not to save the brake pad life as much as because the engine will cool much more efficiently in long downhills than the brakes would if I constantly dragged them. Not to mention I'd be risking brake fade or warping the rotors if not done correctly.
    But as far as general use, such as in the city or coming to a stop sign/light, I just use the brakes as normal
    Chew likes this.
  17. Oct 1, 2023 at 5:28 PM
    #57
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    :fistbump:
    Well, I looked at Earl and his eyes was wide
    his lip was curled and his leg was fried
    and his hand was froze to the wheel
    like a tongue to a sled in the middle of a blizzard
    I says "Earl, I'm not the type to complain
    but the time has come for me to explain
    if you don't apply some brake real soon
    they're gonna to have to pick us up with a stick and a spoon"
  18. Oct 2, 2023 at 1:12 PM
    #58
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Crosstrek....eats brake pads because of the "eye site" cruise control...It applies the brakes once you reach your set travel distance from car in front of you...it ALSO applies the brakes if you're merging onto the highway behind a truck and try to cross over to the middle lane while accelerating..BEEP BEEP BEEP BEEP BEEP...it starts applying the brakes because it thinks your going to rear end the truck while you're gliding across the lane...
    joba27n and ColoradoTJ[QUOTED] like this.
  19. Oct 2, 2023 at 3:11 PM
    #59
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Don't forget when turning, the rear brakes drag a bit to "improve" cornering. Our 2018 Crosstrek rear brakes were done at 35k miles and the fronts looked great. We didn't have the Eye site on this one.
    Now we have a 2022 Limited 2.5 Crosstrek so I will keep a close watch on that.
  20. Oct 3, 2023 at 9:39 AM
    #60
    TreeFortRichard
    Brian
    Well now, that makes a lot of sense...but they really should have gone with bigger calipers/pads if they're going to do that...I had no idea...but those rear pads wear out like front pads! Here car is the top level trim one so it's real nice to drive...
    ColoradoTJ[QUOTED] likes this.
