Engine braking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thatnoobguy, Sep 14, 2017.
  1. Sep 14, 2017 at 5:01 AM
    Thatnoobguy
    Thatnoobguy [OP] Well-Known Member
    Somewhere
    2020 Tacoma trd off road with “premium” audio :|
    12 in sub for actual bass
    I don't know if it's just me but do you guys feel engine braking in 3rd gens? In other cars and trucks you let go of the gas and the car keeps going, slowing down gradually. On the 2017 taco it seems like once you let go of the gas it immediately starts slowing down. Any way to prevent it?
  2. Sep 14, 2017 at 5:30 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I'm not sure to engage engine braking, but there must be something specific because my truck doesn't do it every time.
  3. Sep 14, 2017 at 5:39 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    I really like the engine braking feature.
    Similar to driving stick and downshifting. Thinking it saves me wear and tear on the brakes.
    Don't see it discussed too much on TW though.
    unclebert and 9TRDTCO like this.
  4. Sep 14, 2017 at 5:40 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    shove it in N for 2 seconds shove it back in D...that will disengage a lot of the engine braking
    for the current downhill...until you do something like add throttle or hit the brakes
    at least that's how it's done on 2nd gens like my 2013
    TacoJova likes this.
  5. Sep 14, 2017 at 5:55 AM
    Thatnoobguy
    Somewhere
    The braking is ok for when coming to red lights but when driving on the highway and you let go for a second it drops 5-ish mph
  6. Sep 14, 2017 at 7:11 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    normal. don't take foot completely off gas on highway then it won't happen. who does that ?
  7. Sep 14, 2017 at 7:29 AM
    cheuer
    cheuer Well-Known Member
    Utah
    2016 DCSB TRD OR 4x4 Blazing Blue Pearl
    Leer 100XR, Mobtown Offroad Sliders
    Try using the cruise control on the highway instead, then you don't have to hold the gas pedal down. :thumbsup:
  8. Sep 14, 2017 at 7:49 AM
    ak49watson
    ak49watson Cuts Right
    Alaska
    2017 Barcelona Red Tacoma TRDOR DCB 6MT Tech
    DFCO, deceleration fuel cut off. Pretty much everything has it now. It's part of why we get 20mpg instead of like, 12.
    Pabloeeto likes this.
  9. Sep 14, 2017 at 2:00 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    My taco did that exact same thing and my 4runner does similar, except instead of just losing speed it lets rpms rise instead of going into the next gear. Like it self prohibits moving to a higher gear. I think it's called grade logic or something like that. All forms of engine braking I guess, helps save brake wear, so it suits me just fine!
  10. Sep 14, 2017 at 2:05 PM
    Thatnoobguy
    Somewhere
    I guess it's there for a purpose I just hate that letting off the gas makes it decelerate so quick. Can't cruise down an exit ramp or to a red light
  11. Sep 14, 2017 at 2:06 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Part of it is wind resistance; you've got a brick with a parachute on the front, so when you let off of the gas on a level surface it's going to immediately start slowing down. It's not usually as obvious with cars because their body designs tend to be slipperier than trucks and so their wind resistance is much lower.
    On a downhill slope, it'll downshift if you step on the brakes to aid in stopping. Even if you just lightly touch them. It's made more intrusive by having the truck in tow/haul mode, since it assumes you're stopping a trailer too.
  12. Sep 15, 2017 at 4:16 PM
    Duff49
    Duff49 Well-Known Member
    Bucks County PA
    17 Sport TRD DCLB Barcelona Red
    Mine seemed to do it sporadically. Then it stopped altogether. The only down shifting I notice now is, when slowing down, it will downshift at 1000 RPM. My guess it's doing that because the motor would probably bog and stall if you needed some power quick below 1000 RPM.
  13. Sep 15, 2017 at 7:34 PM
    NJTaco08088
    NJTaco08088 Well-Known Member
    2017 DCLB SR5 4x4
    My truck does it to, going down hill it will slow down rather than coast. Doesn't make sense to me. I would think mpg would increase if the truck would coast, at least coast downhill.
  14. Sep 15, 2017 at 8:22 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Brake pads, rotors, shoes, fluid, and drums are Much cheaper than a transmission rebuild.
    cruxofthebisquit and TPowered1 like this.
  15. Sep 15, 2017 at 8:50 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    According to top gear, newer vehicles (since the late 90s) don't use fuel when engine braking. So technically you'd get worse mileage when coasting because you burn some fuel at idle.
  16. Sep 15, 2017 at 9:45 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I pointed out that fact around here once... I was promptly shit on by at least 3 people.
  17. Sep 16, 2017 at 12:39 AM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    And here on my MT truck, I find the engine braking extremely lacking, it runs away on hills, off roading, and when coming to a stop you can literally feel the fuel cutoff as it feels like the truck shifted itself to nuetral it just feels like it free wheels
    shakerhood likes this.
  18. Sep 16, 2017 at 1:09 AM
    Clearwater Bill
    Billy
    Largo Florida
    At 'coasting' you are moving, thus getting great MPG.
    At idle you are sitting still, so you get 0 MPG.
    cruxofthebisquit likes this.
  19. Sep 16, 2017 at 7:56 PM
    eurowner
    eurowner Duke Sky
    Scoty
    They must have never shelled out thousand of dollars to have their transmission rebuilt due to using it as a brake.
  20. Sep 16, 2017 at 10:12 PM
    Toyo_newb
    Toyo_newb Well-Known Member
    Matthew
    2017 DCLB TRD OR 4x4 QUICKSAND
    Good for the motor too. I click mine over into S and do it myself fairly often.
    CusterFan likes this.
