engine breaking???
Discussion in 'Toyota Trucks & SUVs' started by Pizzalm, Apr 20, 2013.
  1. Apr 20, 2013 at 7:42 PM
    Pizzalm
    Pizzalm [OP] New Member
    Bend, OR
    Tacoma SR5
    3" Lift
    Hello I have a new 2013 Tacoma SR5 and was going around a sharp corner at about 45 when the truck made a sound and began breaking it,s self. It only lasted maybe 2 seconds. Is this normal?
  2. Apr 20, 2013 at 7:44 PM
    Large
    Large Red
    Break =/= brake. Elaborate more.
  3. Apr 20, 2013 at 7:53 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    did you have 4x4 on?
  4. Apr 21, 2013 at 5:16 AM
    Pizzalm
    Bend, OR
    Tacoma SR5
    3" Lift
    Engine braking was the only way I could relate it too.It seemed as the truck could tell that the corner I was taking might have been too sharp for the speed and slowed its self down. I don't think it was the engine it's self but I was definitely slowed down. Is this apart of the traction control or something?
  5. Apr 21, 2013 at 5:31 AM
    Large
    Large Red
    Sounds like VSC kicked in
  6. Apr 21, 2013 at 5:35 AM
    mnerren
    mnerren 2006 Tacoma TRD Sport XSP
    Jacksonville, FL
    2006 Tacoma TRD Sport Double Cab
    Mine doesn't have Stability or traction control. I thought you meant the engine broke, as in blew up.
  7. Apr 21, 2013 at 5:41 AM
    GTechoma
    GTechoma Well-Known Member
    GA
    '10 TRD Sport DCLB 4WD
    EGR inchannel vent visors, OEM bed mat, Wet Okole front and back seat covers, BFG AT's
    ^ This. I have only noticed the "engine braking" when going down an incline/grade that causes the rpm's to jump, but the truck is slower to shift -- best way to explain the feeling that I can come up with. Also, when you let off the gas, you can feel the engine brake some as you coast.
  8. Apr 21, 2013 at 5:41 AM
    WhiteTailPaul
    WhiteTailPaul Member
    Paul
    Northern Wisconsin
    2011 Tacoma
    Lifted
    Sounds like VSC,your trk sensed body roll or slide and automatically applied the proper brake to correct it
  9. Apr 21, 2013 at 5:58 PM
    Pizzalm
    Bend, OR
    Tacoma SR5
    3" Lift
    Thanx guys for the input!
