Engine chirp only when warm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Theo, Mar 5, 2014.
  1. Mar 5, 2014 at 8:13 PM
    Theo
    Theo [OP] Member
    SoCal
    05 trd or
    Once my 4.0 on my 2005 warms up it starts a constant whine that gets louder and changes pitch with rev. I have changed belts,no change changed alternator,no change, changed idler pulley again no change. Any ideas, similar problems?
  2. Mar 5, 2014 at 8:15 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Is the belt to loose or to tight?
  3. Mar 5, 2014 at 8:16 PM
    Theo
    Theo [OP] Member
    SoCal
    05 trd or
    Belts are good, made the noise with no belts
  4. Mar 5, 2014 at 9:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That would likely be an internal issue with No Belts and it still made the same noise.
    Is this noise when just sitting out of gear and running the engine or when moving down the road?
    Have you tried a stethoscope to pin point the general area the noise is coming from? They are cheap and a valuable tool when looking for noise.
  5. Mar 5, 2014 at 10:17 PM
    Theo
    Theo [OP] Member
    SoCal
    05 trd or
    Makes noise at idle clutch in and out. Makes noise when moving as well. Have tried to pin point, me and my mechanic can't figure it out. Trying to see if anybody has had this saving me from unnecessary opening of engine.
