Engine Chirping mp3 attached
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Jan 15, 2010.
  1. Jan 15, 2010 at 5:38 PM
    ywen
    ywen [OP] Well-Known Member
  2. Jan 15, 2010 at 6:01 PM
    Tacoguy
    Tacoguy Well-Known Member
    Alex
    Chicago
    03 Tacoma PreRunner V6 3.4 TRD
    Bed Liner, Running Boards, Cargo Net, Deck Plate Mod, K&N Air Filter, NGK Iridium Spark Plugs
    This sort of sounds like the noise I have been noticing from my Taco. However I have noticed that it is a lot louder when it is really cold outside. Is yours like that too?
    I am thinking that its the belt, but it could also be a belt tensioner.
  3. Jan 15, 2010 at 6:10 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    spray some wd 40 on each belt while its running,if it stops it's the belt
  4. Jan 15, 2010 at 7:27 PM
    ywen
    Hey Tacoguy - I'm in Chicago as well.. today's 24deg when I made that recording..
    I noticed it the other day on the way back from work whilst stopped next to a concrete barrier.. then later on in my commute the sound seemed to have gone away.
    Then today on my commute back, the chirp was there all the time, but then again my commute today was only 6 miles...
    Does the sound go away after driving for a while?
    Don't think that's a good idea.. wd40 will make it worse and might even damage the belt..
  5. Jan 15, 2010 at 7:50 PM
    Tacoguy
    Alex
    Chicago
    Mine does tend to go away after being run for a little while. Today since it seemed to be a lot warmer :D, it seemed to chirp less. However during the last couple of weeks of sub 20 degree whether, it has been chirping loudly.
  6. Jan 15, 2010 at 7:58 PM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, adjustable Bilstien 5100's up front, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Kenwood 350 watt amp, stickers, Better Built toolbox, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 33x12.5x17 General Grabber AT2, Fuel Off-Road Trophy d551 in 17x8.5, BHLM, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro Dry-S drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear plate with swing out and full size spare, SOS bolt-on sliders with kickout, 20" LED bar on main hoop, flush mount pods in rear plate bumper for aux reverse lights
    could be because the belt is cold and does not want to expand as easily as it would if it was warmer out
  7. Jan 15, 2010 at 8:03 PM
    ywen
    A colder belt would shrink.. increasing tension.. a warmer belt is looser and reduces tension. We all know a loose belt would squeal.. not sure if this problem is due to that...
  8. Jan 15, 2010 at 10:27 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'll bet its the A/C idler pulley.
    Do you do any offroading or exposed to water ?
    The A/C idler pulley is the lowest pulley and often exposed to more moisture causing the bearing to go bad.
    It's an easy and pretty cheap fix. Years ago, the dealerships were selling the entire pulley for $35. I actually replaced only the bearings - but the grease seeped out withing 24 hours. So....you can't slap any-old bearing in there. It's gotta be a special bearing that can handle the Rpm ranges. I ended up buying a pulley from toyota.
  9. Jan 16, 2010 at 12:36 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    sounds like what my throwout bearing is sounding like right now. but mine goes away if you slightly push on the clutch
  10. Jan 16, 2010 at 1:22 AM
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    yeah I got the bearing noize too now. see if it goes away when you press on the clutch a little.
  11. Jan 16, 2010 at 5:10 AM
    ywen
    Oh forgot to add that I have an auto... So how do I test that theory? Thanks
  12. Jan 16, 2010 at 5:17 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Did you really just suggest that someone spray a lubricant on an accessory belt?
    Don't do this^^^ Try some belt dressing if you suspect the belt.
  13. Jan 16, 2010 at 5:18 AM
    JDMcQ
    Sounds just like my truck, but mine is more red.
  14. Jan 16, 2010 at 5:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    do not do this!
    x2.
  15. Jan 17, 2010 at 12:56 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine squeaks right when I start it in the morning. I start it, go inside to get my backpack and phone and stuff, and when I come back out it's usually fine. I think it's just your truck complaining about getting up early when it's cold.
  16. Jan 17, 2010 at 1:05 PM
    Tacoguy
    Alex
    Chicago
    X2
    Yeah, since the temps have been a little bit warmer lately, my truck hardly makes any kind of chirping noises anymore.
  17. Jan 17, 2010 at 1:11 PM
    MowTaco
    Kansas
    Last week, we were below zero every day. Thank God we had snow days Wed, Thrs, and Fri or Taco would've been bitching all the way to school.
  18. Jan 17, 2010 at 1:19 PM
    Tacoguy
    Alex
    Chicago
    Oh yeah I know how that is. I got a prerunner, so RWD sucks in the snow. Although I got to admit, it is pretty fun in the snow! :D
  19. Jan 17, 2010 at 6:11 PM
    ywen
    I sprayed the belts with some Belt Dressing and the sound went away.. Hmm looks like I need to tighten the belt a bit? How do I do that?
