Engine Chugging Noise Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xzvr, Mar 26, 2025.
  1. Mar 26, 2025 at 8:50 PM
    xzvr
    xzvr [OP] Member
    Xavier
    2019 Silver Tacoma TRD Sport
    Stock
    Hello I have a 2019 Tacoma TRD Sport with 85k miles. I have started to notice this engine noise while idling and driving ever since some friends pointed out that their Tacoma's don't make the same noise. I have tried to do some research online and heard that the noise was normal, or it was a cleaning cycle, but I hear this noise almost every time I start the truck and drive it. I hear it a lot after driving for 15 min+ and i put it in park and Idle. I have taken it to my mechanic and they couldn't seem to find the issue, they replaced the oil and filter, added the oil booster, and replaced transmission fluid, but no luck and are recommending me to take it back to the Toyota Dealership. I have been on top of oil changes and maintenance. I am just concerned and wanted some guidance on what steps I should take moving forward. Is this noise normal? or should I take it to the Dealership? Any advice helps thank you so much.
    Here is a video of the noise:
    https://www.youtube.com/shorts/B7f9XJbS6lo
  2. Mar 26, 2025 at 9:13 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    That doesn’t sound normal to me I would start by raising the hood and see if the sound is coming from the right side (passenger side) near the right rear corner of engine. If so it may be your vacuum pump that’s failing.
    It could also be the HP fuel pump near the same location as vacuum pump although the HP fuel pump is more of a ticking sound.
  3. Mar 26, 2025 at 9:25 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
  4. Mar 26, 2025 at 9:31 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The noise in the video is somewhat muffled and so it’s hard to tell, but that the speed/frequency of the noise and the tone makes it sound like a tapping lifter to me. There have been a number of times on mine where I hear a loud tapping 5 or so times a second which is about right for valve noise at an idle of 600 rpm.
    My guess is one of the hydraulic lifters fails to pump up and creates some slop in the rocker.
    Does the noise kind of go away if you build oil pressure by revving the engine up?
    Phlogiston likes this.
  5. Mar 26, 2025 at 9:39 PM
    xzvr
    xzvr [OP] Member
    Xavier
    Stock
    It is on the right side, near the valve cover area per my mechanic. But they didnt want to go further to try and avoid costs
  6. Mar 26, 2025 at 11:19 PM
    xzvr
    xzvr [OP] Member
    Xavier
    Stock
    i will record a video of both inside and outside so you can hear both!
    xBloodxLinex likes this.
  7. Mar 27, 2025 at 6:05 PM
    xzvr
    xzvr [OP] Member
    Xavier
    Stock
    I drove home from work, 1 hr drive. Here is a 3 min video, in the cabin, on the sides and under the hood. I know its a little dirty atm please forgive me.
    https://youtube.com/shorts/Gr7fsYS92UI?si=RY-dypZm3x_zSzhX
  8. Mar 27, 2025 at 6:09 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    HPFP from the sound of it if it hasn't been replaced. They had issue with those in 2019.
  9. Mar 27, 2025 at 6:43 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
  10. Mar 27, 2025 at 6:46 PM
    BLtheP
    Plano, TX
    Hard to say but I don’t hear anything concerning. Sounds like mine best I can tell. Maybe in person I’d think differently, but it’s really hard to say.
  11. Mar 27, 2025 at 6:52 PM
    Bishop84
    Bishop84 Well-Known Member
    Not to scare you, but that sounds like bottom end.
    Don't take it to the dealer unless you intend to trade it in. If you do get a shop to look at it, ask them to keep it off record or word it so it doesnt pop up.
  12. Mar 27, 2025 at 6:58 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    That's an old Tractor engine you got in there.
  13. Mar 27, 2025 at 7:02 PM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    That is without a doubt, 100%, your vacuum pump. Mine knocks, there IS a TSB for it, but I still have yet to get it replaced. It's not hurting anything at the moment. Hope this helps!
    pdxTacoSR5, wilcam47 and t0p_d0g like this.
  14. Mar 27, 2025 at 7:03 PM
    BLtheP
    Plano, TX
    Not saying you’re wrong, but that doesn’t sound like the vacuum pumps I’ve heard. I don’t really hear anything in the latest video.
  15. Mar 27, 2025 at 7:07 PM
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    Weird, when u were inside it did sound weird but outside mine sounds same too
    BEFORE YOU PLAY, KNOW THAT ITS LOUD!
    https://www.youtube.com/shorts/L_-rf8_IchE
    This is mine when hood is popped. When I am in the cabin, it does sound like diesel, I am just looking at MPG and keep checking dipstick once every 2 weeks to tell myself that it is all okay. If something was wrong I assume MPG would tank hard and i would see something in the oil
  16. Mar 27, 2025 at 7:08 PM
    Pwakchop
    Nate
    Georgia
    I think the area in the video of the engine bay that he points to is also exactly where the vacuum pump lies. Here's a few threads to compare sounds, if it isn't the vacuum pump, both my truck and I are VERY screwed :rofl:
    https://www.tacomaworld.com/threads/engine-ticking-knocking.794152/
    https://www.tacomaworld.com/threads/engine-knock-loud-and-rough-idling.799099/
    https://www.tacomaworld.com/threads/engine-knock.794294/
  17. Mar 27, 2025 at 7:08 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    C'mon. Mine sounds like this since 2021-22. Bottom end has not left the chat yet.
    wilcam47 and Pwakchop like this.
  18. Mar 27, 2025 at 7:09 PM
    Bishop84
    I hear a knock in some of the angles. And he’s compared to others with the same engine.
  19. Mar 27, 2025 at 7:09 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    sounds like an exhaust leak to me. But could be this...
  20. Mar 27, 2025 at 7:11 PM
    Vlady
    Issy, WA
    I think this is cause by hydro lifters. Just a few rpms clear the noise.
