Engine Chugging Noise Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xzvr, Mar 26, 2025.
  1. Mar 27, 2025 at 7:12 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Pwakchop likes this.
  2. Mar 27, 2025 at 7:15 PM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    t0p_d0g[QUOTED] likes this.
  3. Mar 27, 2025 at 7:25 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    The issue is related to a common denominator.
    OPs. mine and your are a different year models , but has a vacuum pump.
    Or hydro lifters getting sticky due to the head milling issue.
    If you look at all examples, it is always the right(pax) side. They right side has chronic issue leaking oil and afr imbalance codes
  4. Mar 27, 2025 at 7:32 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
  5. Mar 27, 2025 at 7:39 PM
    xzvr
    xzvr [OP] Member
    Xavier
    2019 Silver Tacoma TRD Sport
    Stock
    This is all such great info. You guys are so awesome for taking some time to help me. I have a TRD sport and the 2 i compared to were TRD offroad. One 21 and one 20.
    I can make any more videos to help with the sound just, let me know where to stand or to rev or anything. or even video chat if any are willing.
    Im just worried. I bouhght it exactly a year ago with 60k miles. I heard the knocking/chugging noise faintly in the test drive but ive never owned a truck before to know if that noise was good or not. I really hope its not the bottom end, i would be devestated.
    What are some other symptoms of bottom end, HPFP, or Vacuum pump? I can tell what else im experiencing if i know.some other symptoms possibly?
    Thank you guys again
    Canadian Caber likes this.
  6. Mar 27, 2025 at 7:40 PM
    Vlady
    Issy, WA
    Now you can educate your friends
  7. Mar 27, 2025 at 7:41 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    You can’t compare the noise to the OR model it doesn’t have this type of vacuum pump.
  8. Mar 27, 2025 at 7:48 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
  9. Mar 28, 2025 at 5:56 AM
    abhamber
    abhamber Well-Known Member
    Aman
    Alberta, Canada
    2018 BBP Tacoma TRD Sport DCLB
    I would agree. Mine sounds the same especially after the engine has fully warmed up. Currently at 150,000KM (94K miles).
    BLtheP[QUOTED] likes this.
  10. Mar 28, 2025 at 7:35 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The vacuum pump is on the right rear of the engine, but I don’t hear anything that sounds like the vacuum pump acting up. They make a clackety racket when they go. I don’t really hear that here.
  11. Mar 28, 2025 at 11:56 AM
    xzvr
    xzvr [OP] Member
    Xavier
    Stock
    Ive been told about the HPFP andVacuum pump. What should I look for to help me determine what is going on? Are there other symptoms of these going out?
    Thank you all again
  12. Mar 28, 2025 at 11:58 AM
    BLtheP
    Plano, TX
    I don't think it's the high pressure fuel pump at all. Those make a chirping noise or they leak fuel, that is all they are known for.
    The stethoscope idea is a decent one, maybe put it back there on the vacuum pump. I don't think you have a vacuum pump problem though. Based on your latest video I don't think you have a problem. But that's just going off the video.
  13. Mar 28, 2025 at 2:16 PM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    It’s from the vaccuum pump which is sitting right behind bank 1. I took my 22’ manual to the dealer multiple times for this and they did nothing but diagnose it to be coming from the vaccuum pump.
    HPFP sits right in between that and where you can hear it from the most on the passenger side
  14. Mar 28, 2025 at 2:23 PM
    danny15l
    nada
    That TSB is edited to not include the tacomas. Either that is true or my Toyota dealer made a fake document that the NHST doesn’t know of.
    pdxTacoSR5 likes this.
  15. Mar 28, 2025 at 2:51 PM
    #35
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I just read that revised TSB what a bitch. I have one year left on my factory warranty and if mine starts making the slightest noise hopefully they will replace it under warranty and I might as well be looking at an extended warranty.
  16. Mar 28, 2025 at 3:20 PM
    #36
    danny15l
    nada
    Also I just called corporate and they said it’s up to the dealers to post in the NHSTA apparently. They actually just updated it again in August of 2024 to include the tacomas. Sorry this is just new information today for me. Same TSB. I’m scheduling an appointment
