Engine code after new alternator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lilmink, Feb 15, 2024.
  1. Feb 15, 2024 at 11:20 AM
    Lilmink
    Lilmink [OP] Well-Known Member
    2006 Tacoma
    Replaced alternator in v6 2006 Tacoma, drove for a few miles , engine light came on.
    P0335 crankshaft position sensor a
    P0776 pressure solenoid b performance or stuck off
    C1241 low or high power supply voltage
    Could these sensors be acting up because of the new alternator? Please advise.
  2. Feb 16, 2024 at 2:02 AM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    It “should not” I replaced my alternator, and no problems or codes.
    Check the fuses and make sure the belt correct?
    Did you unplug anything else’s but the battery and the dead alt wires?
    I can’t say much further as those sensors / diagnostics I’m not familiar with. Don’t want to give wrong information.
  3. Feb 16, 2024 at 7:52 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I'd say you likely have some lose connections or unplugged harness.
    Did the alternator require replacement because the bearing/pulley sized? If so a broken serpentine belt may have cut some wires in the engine bay when it happened. Just try and inspect the engine bay for loose wires, cut wires and unplugged harnesses.
    I just saw that last code. I think you may have gotten a bad alternator and the other codes are likely a result of that.
    Tacoma Mike likes this.
  4. Feb 16, 2024 at 1:12 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    if a new alt loses a diode, AC will be applied instead of DC and do weird things to sensor readings
    winkel likes this.
  5. Feb 16, 2024 at 2:31 PM
    MR5X5
    MR5X5 Well-Known Member
    Inspect connections clear the codes and see if they return. Go from there.
  6. Feb 16, 2024 at 3:22 PM
    Waasheem
    Waasheem
    2007 xrunner
    Yup. Hit erase codes. Turn the engine off, turn it back on, see what comes back if anything.
