Engine Code P0420
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bthrasher, Oct 1, 2023.
  1. Oct 1, 2023 at 12:04 PM
    bthrasher
    bthrasher [OP] New Member
    Ben
    2019 Tacoma SR
    I had my CAT converters stolen, and then got after market replacements. The truck runs great but after two days the check engine light came on and threw this code (P0420). The truck is still running great, but why is it throwing this code and how do I fix it?
  2. Oct 1, 2023 at 12:08 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My experience with aftermarket cats hasn't been all that good, as some will throw the cel, or it could be a faulty o2 sensor now.
  3. Oct 1, 2023 at 12:39 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Fkin Cat Thieves should be castrated then hung from from the nearest tree whilst
    being beat with a baseball bat and left there to rot. Hang a big sign from their feet
    labeled CAT THIEF - see how they like it now.
    shakerhood and dil like this.
  4. Oct 1, 2023 at 12:43 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Check your 02 sensors.
  5. Oct 1, 2023 at 1:06 PM
    eon_blue
    Azusa, CA
    If they didn't install them correctly and there's a leak, the O2 sensors will read the cats as being bad and trigger that code. Either that or the aftermarket cats they installed were poor quality and not satisfying the parameters of the O2 sensors. The cheap ones have way less of the (expensive) material in them that filters the exhaust gases.
    OEM cats are crazy expensive not just because Toyota sells them. Magnaflow or Walker are the only aftermarket brands I'd trust personally.
    zoo truck likes this.
  6. Oct 1, 2023 at 1:08 PM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    I had a crack in the weld on the flange of my drivers side cat and it threw this code. It could be anything up or downstream from the cats from a loose seal, to a crack, to a dirty or faulty or misinstalled O2 sensor.
    Take it back to whoever did the replacement work and have them check it. If it a leak it’s usually pretty easy to find.
  7. Oct 1, 2023 at 7:39 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    You can go to brasil and your wish can come true , nowadays people just get cancelled for saying the wrong things lol
