Engine Codes--Resetting Leaves a Trail?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomaatw, Nov 4, 2009.
  1. Nov 4, 2009 at 6:36 PM
    tacomaatw
    tacomaatw [OP] Well-Known Member
    Marc
    010 TRD Off-Road Super White
    Avid Off-Road Bar, Superbumper, Weathertechs, Hunter 4x4 Nerf Bars
    I had posted this in "Technical Chat," but I really need more responses. I want to put a locking fuel cap on my truck:
    I've only got about 340 miles on my 2010, but I installed a locking gas cap (CST, from AutoZone). Apparently, it threw a couple codes--CEL along with a slip indicator.
    AutoZone checked the codes for me, and there was an emissions leak--likely the gas cap. They gave me a non-vented CST gas cap, but I didn't have them reset the codes so that I could get the slip indicator checked out a the dealer.
    I was worried about the slip indicator, but the dealer said there was no problem. Since I had the locking gas cap, a non-sanctioned Toyota product, I was charged a diagnostic fee (1/2 hour of labor) to check out the emissions problem.
    I would like to keep the locking gas cap. In fact, I haven't even given the new, non-vented cap a chance to work.
    My question: if I buy a code reader and reset the codes myself, will there be a record of codes in the computer that the dealer will see I reset myself? I don't want there to be a warranty issue later, and I also want some security for my gas tank.
    **In sum, if I reset the codes, will the codes still be left for the dealer to find later (i.e. months from now).**
  2. Nov 4, 2009 at 10:15 PM
    tacomaatw
    Marc
    bump.
    Please help, if possible. I'd like to use the locking gas cap.
  3. Nov 4, 2009 at 10:20 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Yea if u erase the code its gone. also if some how the dealer found that ur truck through this code u can just say the gas cap wasn't tight once.
  4. Nov 5, 2009 at 7:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    Are you worried some one will steal the gas?
  5. Nov 5, 2009 at 7:52 AM
    stang88
    stang88 Well-Known Member
    what other purpose does a locking gas cap serve?
  6. Nov 5, 2009 at 7:52 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I also got a locking gas cap... Since the gas door doesn't lock, all you can do is hope no ashole dumps something down your gashole. :eek:
  7. Nov 5, 2009 at 7:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    Considering there is a strainer in the tube which prevents theft. That was my concern.
  8. Nov 5, 2009 at 8:28 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I think that strainer can be punctured pretty easy with a stiff rubber hose.
  9. Nov 5, 2009 at 8:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It cant. Many people have tried to get fuel out of their own vehicles for lawnmowers, etc, and havent been able to get gas out.
  10. Nov 5, 2009 at 8:32 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    id be careful with locking gas caps. Some people in my town actually had locking gas caps when prices were really high, and the crooks just cut there fuel line and got the gas out. Which costs more to fix then the gas they were protecting.
  11. Nov 5, 2009 at 8:32 AM
    PropJet
    PropJet Well-Known Member
    KS
    '09 DC TRD Off Road
    ToyTec Ultimate Lift Kit, Moto Metal 955's, GoodYear DuraTrac 265/75/16's, N-Fab Nerf Bar
    That's actually kind of funny. The thought of someone vandalizing their own vehicle, that is.
  12. Nov 5, 2009 at 8:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have tried it with my vehicles....Need a gallon of gas, to lazy to run to the gas station, .......
  13. Nov 5, 2009 at 8:36 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    This is kind of hard to explain, codes don't really disappear though. The CEL won't always come on the first time a code is thrown either. Usually, the ECU sees the code and after 'X' amount of times the problem is encountered, the CEL is illuminated. There is a history associated with each code, where that cut off is depends on the specific code.
  14. Nov 5, 2009 at 8:37 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Once you erase the codes they are gone. Did that with the Subaru I traded in for the Taco. It dropped a cylinder and I erased the code as I pulled into the stealers lot. They had no fricken clue.
  15. Nov 5, 2009 at 8:40 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    Great you and gas :D
  16. Nov 5, 2009 at 8:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :anonymous: I dont mess with that shiot anymore.
  17. Nov 5, 2009 at 8:57 AM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    I think that's the drive cycle you're referring to. Part of the logic of the ECU. :thumbsup:
  18. Nov 5, 2009 at 9:12 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Yea, that's it.
