engine codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bowhunter197, Sep 21, 2015.
  1. Sep 21, 2015 at 2:15 PM
    bowhunter197
    bowhunter197 [OP] Member
    Scott
    2007 tacoma
    Are cold air intake, 3inch icon stage 2 lift procomp wheels
    So my check engine light came on and i have 2 codes. One is a p0011 and the other is a p0016. The p0011 is a cam pos.actuator and the p0016 is a cam/crank pos.correlation sensor. Both are for bank 1. Ive been reading and seen it could be a number of other sensors making these codes appear. Has anyone had these appear on their truck. Im not sure what to replace first.Any help would be great. Thanks
  2. Sep 21, 2015 at 4:25 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would actually say the odds are high that it is the CAM Position Sensor ( this is the one that the rodents love to chew on the wires ). The Cam/Crank Position Correlation would also be caused by the Cam Sensor as all it means is that the Cam and Crankshaft seem to not be in time with one another.
  3. Sep 22, 2015 at 2:22 AM
    bowhunter197
    Scott
    2007 tacoma
    Thanks Jimmy for the advice but i have a question maybe you have an answer for. Should i bother with the oil control valves as that's another thing I've read that would make these codes appear? Thanks again
  4. Sep 22, 2015 at 10:18 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes, That is a good possibility also. the Oil control valve getting stuck would indeed cause these codes. It could also be the oil control valve filters...
    When you check the oil control valve the resistance of the coil should be ; "> 6.9 to 7.9 at 20°C (68°F). As per the service manual.
  5. Sep 1, 2023 at 8:34 PM
    wailua05
    wailua05 New Member
    Dave
    2005 silver
    front levelled with eibach springs, bilstein shocks
    2005 4.0l with 211000 miles.
    I had p0011 and p0016 with check engine light on. Very rough idle and difficult driving at low speeds with the manual transmission , wanting to shudder and buck , only way to drive is with some extra throttle and lower gear . Replaced bank 1 , passenger side vvt solenoid/oil control valve $180 ,and camshaft position sensor $94 , --- fixed and check engine went away after a couple of stops .
