Engine computer pooped!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Biged_72455, Dec 31, 2019.
  1. Dec 31, 2019 at 7:28 AM
    Biged_72455
    Biged_72455 [OP] Active Member
    99 Tacoma sr5 2wd 2.4
    Friends 99 Tacoma engine computer up and totally quit at 2:30 AM. I have ordered a new one, but need to know just how difficult it is to get them swapped out. I read that they are behind the glove box. Does anyone have any additional information regarding this? Tools needed? Any specialty items or stuff to watch out for?
    CS_AR likes this.
  2. Dec 31, 2019 at 8:02 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Going to play devils advocate here; how do you know the pcm quit?
    What if it's a bad ground or something causing some weird/no start situation?
  3. Dec 31, 2019 at 8:08 AM
    Biged_72455
    Cause it was running perfectly fine and just straight died. Took it to shop and it’s showing no communication to the scanner. Haven’t done anything but changed fuel pump cause I thought it was fuel pump. No spark, no fuel pump prime, but it does crank over fine.
  4. Dec 31, 2019 at 8:09 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Try a different scanner.
    GQ7227 and Kwikvette like this.
  5. Dec 31, 2019 at 8:11 AM
    Biged_72455
    A $16,000 snap on scanner needs to be tried with a different scanner?
    Rachelsdaddy, GQ7227 and suaveflooder like this.
  6. Dec 31, 2019 at 8:13 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Many 1st gen owners wrench on their own cars and have done so on other cars as well.
    Start with basic trouble shooting steps before throwing money at it all because a scanner told you to do so.
    GQ7227 likes this.
  7. Dec 31, 2019 at 8:14 AM
    T4RFTMFW
    :facepalm:
    Truck is totaled. You’re right. Adios.
    otis24 and GQ7227 like this.
  8. Dec 31, 2019 at 8:22 AM
    Biged_72455
    I tried it with my cheap Bosch scanner. Same thing. No communication, link error.
  9. Dec 31, 2019 at 8:24 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
  10. Dec 31, 2019 at 8:27 AM
    Biged_72455
    I did basic trouble shooting.
    No spark
    No fuel pressure
    No fuel pump priming.
    Battery is good and hot @14.7v dc
    Checked every fuse in the truck.
    All are good.
    that is why I trailered it to be scanned.
    2 different scanners show no communications.
  11. Dec 31, 2019 at 8:35 AM
    Biged_72455
    thank you. That helps a whole lot.
    and I checked all the fuses in both fuse boxes trying to find one blown. All were good.
    CS_AR[QUOTED] likes this.
  12. Dec 31, 2019 at 8:54 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    I had to replace one in my M3. It’s not hard to replace them. It’ll take you longer to get to it. Clips should be similar and are the ones where you slide the “hood” up or down and the clip slides in or out . Sorry, best way I can think to describe it.
  13. Dec 31, 2019 at 8:55 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    While they do fail about the only thing that takes them out is water and a huge Voltage spike
    Been doing any welding with the battery not disconnected ?
    Been using the truck underwater?
    As for as changing them plug and play 10mm nut driver
    GQ7227 likes this.
  14. Dec 31, 2019 at 8:55 AM
    Biged_72455
    I watched the video. That gave me a really good idea what to expect.
  15. Dec 31, 2019 at 8:58 AM
    Biged_72455
    it’s not my truck. But she does use it for a newspaper route. Recently had a bad alternator replaced, then a bad battery replaced. Fortunately both items had lifetime warranties and did not cost her anything to fix but an hour labor on the alternator and nothing for the battery.
    No welding done to the truck at all best of my knowledge.
  16. Dec 31, 2019 at 10:25 AM
    Biged_72455
    Already did that. I have a bunch of fuses from scrapped vehicles and I swapped them all out. Still the same.
  17. Jan 7, 2020 at 11:29 AM
    Biged_72455
    Turned out it is a fuse that is blown.
    But it keeps blowing them as soon as I turn on the key.
    AM1 is the control circuit for fuel and engine computer.
    AM2 is for the starter.
    I replaced AM1 with all the way to a 50 amp and it popped every one.
    I will have to go get more fuses cause I went thru all the new ones in the pack I JUST bought. And I don't have any more spares.
    Does anyone have any ideas or suggestions as to where I may be able to start checking for this dead short I am encountering?
    The owner is considering it dead for a while unless I can miraculously find the problem area and get it going again.
    All the fuses I had replaced are the mini-fuses I had on hand. I did not have any like the one for AM1 and AM2.
    So to those who suggested the fuses, I must apologize. I did try them, eventually!
    otis24 likes this.
  18. Jan 8, 2020 at 1:45 PM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Hope to learn from you.... After replacing the fuse. (could you please identify which one it was) Did you figure out what was causing the dead short? Did someone connect the battery cables to the wrong terminals. (that's what it sounds like to me.)
  19. Jan 8, 2020 at 2:48 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    If you need a ecm they have all different Pinouts and or plugs every year, engine , Trans and 2wd or 4wd
  20. Jan 8, 2020 at 5:25 PM
    Biged_72455
    Already have a second ECU. Matching numbers for both units.
    The vehicle has some kind of a dead short in the ecu/fuel circuit that the fuse goes to. Bad part is I don't know how elaborate the wiring is to chase down. I put a pair of needle nose pliers in where the fuse goes is how I established it was an actual bad fuse. The engine actually tried to start when I tried the key. That's when I got the new fuses. But all of them are now blown. I don't want to catch the truck on fire trying to chase down the short.
    I have moved the truck out of the garage for now. But will work on it more this weekend to try to chase down where the short is at. I also plan to swap back the original engine computer and see if it might possibly be that.
