Engine Coolant Filter Installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 3MC0R, Oct 23, 2016.
  1. Oct 23, 2016 at 10:51 AM
    3MC0R
    3MC0R [OP] New Member
    2014 Tacoma Baja
    None
    Has anyone installed an engine coolant system filter on the 4.0?
    I was considering the Donaldson, but can't figure out how to fit in under the hood.
    Any thoughts?
  2. Oct 23, 2016 at 11:14 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    What would be the purpose of a coolant filter? For towing?
    Instead of filter you could just change the fluid more often, right?
    Seems like a filter on a coolant system is risky. As filter clogs it will have less flow which isn't good for motor, correct?
    Mush Mouse likes this.
  3. Oct 23, 2016 at 11:17 AM
    3MC0R
    2014 Tacoma Baja
    None
    The filter is side stream so if it did completely clog it would not affect the system at all.
    And yes, its for towing...trying to protect all that aluminum
  4. Oct 23, 2016 at 11:19 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I think there are better things to spend your money on.
    For less money, replace the fluid and radiator in 8 years.
  5. Oct 23, 2016 at 11:32 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I would say its not necessary. Flush the coolant at its regular interval and be done with it.
  6. Oct 23, 2016 at 11:41 AM
    koditten
    Kirk
    Central Michigan
    I would agree. Adding components is only introducing more leak points. The cooling system is filled with long life fluid. It sounds like you are wanting to fix something that isn't broken.
    It is only natural to try to care for a very expensive purchase. Routine, cheap maintenance is the best answer. This site is full of stories of Tacoma trucks going 400,000 miles with regular maintenance.
  7. Oct 23, 2016 at 11:48 AM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    x2: On my '95 I did a drain and refill about every 60-90k, think I used the auto parts store radiator flush stuff most of the time and recall once having it professionally flushed. At about 10 yrs/ 200k I preemptively changed all the hoses and thermostat. Ran that truck 15 years/379 k miles, Never a cooling system failure or needed replacement of the radiator/heater core.
  8. Oct 23, 2016 at 12:15 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Donaldson Coolant Filters - appear to be for Big Rigs - Large Diesel. See the video. Not real sure this applies to smaller automotive gas operation. Change coolant more often if you are concerned.
    https://www.youtube.com/watch?v=oDjUDm_oQ-8
  9. Oct 23, 2016 at 7:16 PM
    3MC0R
    2014 Tacoma Baja
    None
    Appreciate the input.
    Thx
  10. Oct 23, 2016 at 7:24 PM
    koditten
    Kirk
    Central Michigan
    You are welcome.
    And welcome to the show.
  11. Oct 23, 2016 at 8:59 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Never knew such product existed.
