Engine Coolant Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VonHaga, Jul 31, 2021.
  1. Aug 5, 2021 at 11:47 AM
    #41
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Do you have a torch with a trigger on it, or how do you do this? My tig came with a pedal, and it's been limiting for some of the stuff i'd like to do
  2. Aug 5, 2021 at 3:42 PM
    #42
    Waasheem
    Waasheem
    2007 xrunner
    Once I had someone else operate the foot pedal while I laid on my back to weld something. Screaming more more MORE less less more. I thought about making something so I could use my foot while laying down. It was easier to just buy the finger control.
    BassAckwards[QUOTED] likes this.
  3. Aug 5, 2021 at 3:48 PM
    #43
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    Ive done tig with the pedal between my knees or under a leg, however I also have the machine setup for pulse and ramp down.
    For the cooling system it should not be at 27psi especially when its just warming up.
  4. Aug 5, 2021 at 4:29 PM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Foot pedal. I just position it where I can operate the pedal easy enough.
    www.6061.com offers a pressure sensitive switch for the torch handle. Check that out.
  5. Apr 22, 2022 at 7:49 PM
    #45
    VonHaga
    VonHaga [OP] Well-Known Member
    Josh
    2006 Red Tacoma 4x4 Crew Cab
    Just wanted to post an update on this thread! I ended up changing the radiator, thermostat, water pump, and hoses on my truck. I refilled it with coolant and it did the same thing - the coolant bubbled in the reservoir after I drove it hot. I filled up the reservoir with water a little bit and it eventually stopped shortly after the fluid change. I have since driven 5k miles on the truck with no overheating issues or fluid leaks. I'm suspecting there is a large air bubble in the system that eventually makes its way out.
    Don't really think it could be a head gasket since I've put over 5k miles on it with no overheating.
    Weissenheimer and point45 like this.
