Engine cover rear bolt lost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AfJordy, May 27, 2017.
  1. May 27, 2017 at 5:01 PM
    AfJordy
    AfJordy [OP] New Member
    Jordy
    2015 TrdOR Access Cab
    I've tried to find the p/n for these bolts with no luck. I lost one of the bolts that holds the engine cover in place. Not the acorn style but the bracket closest to the windshield side of the cover on the driver side. Does anyone know the p/n for this? Thank you in advance.
  2. May 27, 2017 at 6:45 PM
    Muddinfun
    Muddinfun Well-Known Member
    You mean the bolts that hold the rod thingy? There's 2 bolts. Take the other one out and take it to the hardware store and match it up.
    I recently had my engine cover off and I set the 2 acorn nuts on top of the cover. I picked it up to put it back on and there was only 1 acorn nut. I looked all over the place for about 10 minutes, and couldn't find it anywhere. I finally gave up and put the cover back on. When I pushed it into place, the acorn nut popped out of the hole. I wonder if it's an intentional design that the acorn nuts fit perfectly, upside down, in the holes. When it's in there like that, it sorta disappears.
  3. May 27, 2017 at 7:25 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I removed my engine cover and never put it back on. It looks better without it!
    wiggler and Key-Rei like this.
  4. May 27, 2017 at 7:29 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    But you lose horsepower without it. I think about 25% of the horsepower is in the engine cover.
    grizquad, Drainbung, Sprig and 2 others like this.
  5. May 27, 2017 at 7:42 PM
    AfJordy
    Jordy
    I would like to keep it on. I would think it would help keep heat off the hood but I'm not sure. It is one of the ones holding the rod thing. I didn't know if they were the same or not. I finally found a schematic of it and they are. Thanks for be advice.
  6. May 27, 2017 at 7:45 PM
    Pigpen
    Dan
    Northwest Montana
    And I can hear it ticking from here
    03f5sp[QUOTED] and landphil like this.
  7. Nov 17, 2020 at 12:36 PM
    tacotacolove77
    tacotacolove77 tacotacolove77
    patsy
    Canada
    2015 Tacoma TRD Sport Beautiful white
    it's mine-- graphics white silver horses
    Hello While in shop someone stole my acorn nut and post out of engine cover anyone know where I can get one ? I really think my Truck and the fact I am a woman means you can take parts off my truck .
    Hobbs likes this.
  8. Nov 17, 2020 at 1:26 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Nothing better than tossing the gender card........
    o_O:facepalm:
    grizquad and wiggler like this.
  9. Nov 17, 2020 at 10:06 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are you saying those aren't good reasons?
    LOL, I'm kidding...
  10. Nov 24, 2020 at 7:26 PM
    tacotacolove77
    patsy
    Canada
    Well pardon me but when things are taken from your truck and it was a the dealership and because of Covid I know where it has been and when things go missing . Unfortunately it is quite common with taking advantage of women that bring vehicles in for work to do unnecessary work on them to charge more . Like old jokes of bearings in mufflers . Anyways do you know where I can obtain the acorn nut and post ?
  11. Nov 24, 2020 at 7:29 PM
    tacotacolove77
    patsy
    Canada
    Did you look on skid plate ?
  12. Nov 24, 2020 at 7:35 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The hood doesn't need heat protection. Paint is baked at much higher temperatures than the intake would ever get. The cover is just there to trap dirt and create a nice cozy place for mice to settle in and chew on the $1000 wiring harness.
    tacotacolove77 likes this.
  13. Nov 24, 2020 at 7:37 PM
    Knute
    Do you really believe that only women are targets at a dealer?????
    Do you believe the dealer hangs a sign on the vehicle identifying a Women's Car?
    Geessshhhh. o_O:crazy:
    Oh, to answer your question. Remove the other mating acorn nut and post. Visit the local hardware store, a salvage yard or the dealer parts desk. Make a match with the one in your hand.
  14. Nov 24, 2020 at 11:02 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    I always thought the only purpose of that engine cover was to keep mere peasants from fiddling with anything under the hood that wasn’t certified by the dealer. The first time I had to take it off, I “lost” it.
    tacotacolove77 and mac84 like this.
  15. Nov 24, 2020 at 11:03 PM
    wiggler
    HILO
    Probably ace hardware
  16. Dec 11, 2020 at 1:06 PM
    tacotacolove77
    patsy
    Canada
    Yes I do as if and when my Husband goes with my truck they treat him knowledgeable like he knows but me they will try and pull extras . Actually keep in mind guys in service department are really sales people and need to push services . anyways found a replacement bolt for time being Thank you
    Torspd and Drainbung like this.
  17. Dec 11, 2020 at 1:07 PM
    tacotacolove77
    patsy
    Canada
    Thank you
  18. Dec 11, 2020 at 4:24 PM
    Knute
    Dealers try to "pull extras" no matter who or sex.
    Try not to be so sexist.
  19. Dec 11, 2020 at 7:52 PM
    tacotacolove77
    patsy
    Canada
    Can’t help it -it is my experience
  20. Dec 12, 2020 at 7:00 AM
    Knute
    Rise above.
