engine cutout only on bumps?
Discussion in '4 Cylinder' started by yota new.o, Apr 5, 2012.
  1. Apr 5, 2012 at 11:56 AM
    yota new.o
    yota new.o [OP] Well-Known Member
    joe
    klamath falls oregon
    96 tacoma 2.7 sr5
    fabtech dirtlogic coilovers with all-pro a-arms chevy 63" leaf springs billi 5125 12" extended bore shockins in rear headache rack duplicolor bed armor bumpers kc daylighters front fenders corbeau racing seats custom bed rack
    like the title says my engine will cut out briefly if i go over a bump in the road and at first start up you give it any as and it sputters almost dies but then comes back up to rpm, sometimes when it cuts out i lose sound to my stereo it does not turn off bu the music stops im baffled does any one have an answer. ive checked battery cables, dist. cap, rotor, plugs wires, fuel pump connector, fuel filter
  2. Apr 5, 2012 at 12:05 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    *bump* any info at all?
  3. Apr 5, 2012 at 12:42 PM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    I think you are on the right track, somthing is loose. It could be a broken wire that is not making good connection, but that is much harder to find. I would start playing with things while the engine is running and see if you can kill it by jiggling a conector or harness.
  4. Apr 5, 2012 at 12:52 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    From your description, focus your search around your ignition switch and wires leading to it.
  5. Apr 5, 2012 at 11:41 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    was also thinking they said when my lift got done the battery died on them could it be my battery is slowly taking a dump and it just happens to mess something up with it when i hit a bump this is getting very frustrating thanks for the answers guys gunna try them tomorrow
  6. Apr 5, 2012 at 11:42 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I had a similar issue on my old truck , turned out to be a loose main ground
  7. Apr 5, 2012 at 11:48 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    definatly will check main wires tomorrow then drive down to autozone and test battery and alternator
  8. Apr 6, 2012 at 10:46 AM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    well main wires are just fine, tested battery it was bad took connectors off tested it again and it was good, replaced the connectors and now the problem is worse, but now it acts like its starved for fuel. the is really getting irritatiing im lost guys i need some help
  9. Apr 6, 2012 at 10:51 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    Definetly a wire is loose somewhere are seeing any codes poping up
  10. Apr 6, 2012 at 10:57 AM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    nope no codes just checked that, when i first start it and rev it, it sputters untill it gets into higher rpms, thinking about replacing fuel filter and see what that gets me
  11. Apr 6, 2012 at 11:27 AM
    BAMFTACO
    Jośe
    Taco
    I think I might no what's going on now check your ground and power on the fuel pump because thats what to my buddy's jeep it would stall out every time it would hit a bump and it was the ground wire near the fuel getting loose and starving the engine
  12. Apr 6, 2012 at 10:35 PM
    Gorillazrus
    Gorillazrus To be continued...
    01 Prerunner SR5
    5100 Bilistens set @ 1" in front, Wheelers 5 leaf in rear, Leer Topper, TRD Skid Plate, Dual Band Ham Radio
    I had a similar issue with an old s-10 I had no power, boging down, missing ect. And it turned out that their was an ignition wire to my distrubitor that had chafed through and was grounding out when ever it touched anything metal, could be that when they did your lift they might have pinched a wire some were and it's shorting out.
  13. Apr 7, 2012 at 12:59 AM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    thanks guys for the responses im going to dig into it tomorrow and hopefully solve this issue, looking at it today i found my throttle body was loose and was missing a bolt, a ground wire was not connected and my cap had some crap ont he points, fixed those issues but no change in truck
  14. Apr 7, 2012 at 6:28 AM
    wolftree
    Rick
    Ohio
    Did you clean the battery post terminals and cables when you took them off the battery?
  15. Apr 7, 2012 at 6:44 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check engine ground wires that attach to the frame. 9x out of 10 they are corroded off. I was given (for free!) an old truck that didn't run; brought it home and sure enough the engine ground wire to the frame was corroded off. I sanded clean the frame, put new ground wire end on, gave a Hail Mary and it started right up and ran like a dream.
    Also (just for fun) check the engine wiring isn't burned or pinched especially around the EGR valve.
    Hunting idle is also a sign of vacuum leaks. Check the little vacuum hoses for deterioration and cracks. I'd hit the auto store and buy a roll of new vacuum hose and start replacing them.
    Also, make sure your EGR valve moves freely by pushing up on the diaphram on the underside space provided on the valve. If it does not move freely, buy a new EGR valve.
  16. Apr 7, 2012 at 4:55 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    ok just finished putting in a new cap rotor ign coil and fuel filter. it no longer cuts out on bumps it has good acceleration and good speed but now it misses at 1500 rpm everygear does it when we excelerate and decelerate. and it's a mild miss what do you guys think?
  17. Apr 7, 2012 at 5:23 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I would replace the ignition wires and plugs if you haven't already.
  18. Apr 7, 2012 at 5:39 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    will do tomorrow
  19. Apr 7, 2012 at 11:29 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    any other suggestions
  20. Apr 7, 2012 at 11:32 PM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    Possible the bearings are shot on your alternator
    Go down and tug on the rotor shaft and see if you have any play
