engine cuts out when turning right
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Twiostaco, Jan 10, 2015.
  1. Apr 5, 2015 at 10:18 AM
    mac360
    mac360 Well-Known Member
    Long Beach, Ca
    2017 Tacoma OR DC LB
    Pro grille, GoodYear duratrac 265/75R16, Method Nv, Cbi front bumper , Icon stage 3 w/RXT leaf pack
    I have this same issue.. Although mine has done it with a slight turn just entering a freeway. I'm also driving a 4 cyl. basically seems like loss of fuel to me or like a governor is not allowing the vehicle to accelerate. Definitely scary at times.
  2. Jul 23, 2015 at 7:34 PM
    S13chris
    S13chris Well-Known Member
    Jacksonville nc
    07 dbl cab 4x4
    Tail gate mod, debadged, and weather techs, satoshi grill, diff breather mod, Duratracs 265/70/17, snugtop shell w/ rack, sleeping platform for bed, LED's for interior lights/Reverse lights/license plate, BHLM & DTRL Mod.
    Same issue as well for 07 sport 4x4
  3. Jul 24, 2015 at 9:22 AM
    S13chris
    Jacksonville nc
    07 dbl cab 4x4
    No it doesn't.
  4. Jul 28, 2015 at 3:10 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I had a vehicle that hesitated on acceleration - long story short - the fuel pump. And it did test sort of OK at idol.
  5. Nov 2, 2015 at 5:38 PM
    Twiostaco
    Twiostaco [OP] Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    Sorry to dig an old thread up but i did find resolution... Finally took it into the dealer and there is a sensor that was out of alignment so it kept thinking the brake pedal was being pushed. Toyota readjusted it for free and its driving great. It took me until last week to finally get it resolved.
    Bishop84 likes this.
  6. Nov 2, 2015 at 8:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yeah. That is the software fix for the "unintended acceleration". When if the brake is pressed and the throttle is pressed it cuts the engine power.
    They adjusted the brake switch. As was outlined in Post # 7 and # 12... 10 January 2015.
    Thanks for reporting back.
  7. Nov 2, 2015 at 8:40 PM
    Twiostaco
    Austin
    Utah
    Yesssir it became apparently obvious when i would look outside and my brakes were on.... wiggle the pedal and they would go off.
    Smart people in here... thats why i love this site!
  8. Jan 28, 2021 at 11:51 AM
    rwilsond
    rwilsond Member
    Orange County, CA
    Owns 2008 V6 Dbl-Cab, Short-Bed PreRunner
    N/A
    Not 100% positive, but I suspect overfilling the gas tank may cause this kind of problem; i.e., adding gas after the nozzle has automatically shut-off.
  9. Jan 28, 2021 at 1:56 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Zombie thread.
    It was fixed in 2015 and was the brake switch adjustment...
    Torspd, TnShooter, Muddinfun and 2 others like this.
  10. Jan 28, 2021 at 7:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Strange. :confused:
    How do these old post keep getting brought up out of no where?
    @rwilsond did you use the search function to find this thread?
    No big deal. But this type of stuff happens in spirts.
    Throws me for a loop at times.
    Answering years old question.
    Dm93 and Jimmyh like this.
  11. Jul 20, 2023 at 4:53 AM
    Rexthedog
    Rexthedog New Member
    08 taco 16 taco
    Lifts, cold air, racks, throttle commander, tires rims, power inverter
    I have a 2016 off-road edition Toyota Tacoma that does the exact same thing. Generally speaking it only does it on a couple of turns but it is always the right turn and it is always in this one spot where it's a right turn and you immediately go up a slight Hill. It immediately dies down to no power at all for a couple of seconds and then makes you seem like you're in the giantest biggest sissiest vehicle of all time as you Putt-Putt up the little Hill. This is incredibly unbecoming of a freaking four-wheel drive vehicle that was literally made to kick as* out in the middle of nowhere and climb steep hills supposedly. So my question is if it is the VSC junk, how do I remove that BS VSC system altogether? I had to take my truck in for a recall repair a couple of months ago that was missed on it and they gave me a new Tacoma to drive for the week and I have to be honest it was the worst experience of my entire life but that could be said for just about every single new vehicle out there.
  12. Jul 20, 2023 at 6:27 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^If that was the worst experience of your entire life, you must lead a sheltered life :cookiemonster:
    Jokes aside, check for a misrigged brake pedal switch like originally described in this 2015 necro-thread you dug up. Make sure your truck has done the crank sensor recall.
    Taco 422 and windsor like this.
