Engine damage from parking?
Discussion in '4 Cylinder' started by bicks, Aug 16, 2015.
  1. Aug 16, 2015 at 1:00 AM
    bicks
    bicks [OP] Member
    john
    Sydney Australia
    Hilux 2.7 2wd
    soon
    I have a 2tr-fe, I parked nose up on a steep hill wresting it in 1st gear as the e brake has stretched, can this rotate the engine backward and cause damage?
  2. Aug 16, 2015 at 1:19 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    No, your engine is mounted to the frame. I'm not sure what you mean by rotate the engine, but the engine is not going to move out of place unless your motor mounts are broken or unattached.
  3. Aug 16, 2015 at 1:36 AM
    bicks
    bicks [OP] Member
    john
    Sydney Australia
    Hilux 2.7 2wd
    soon
    I'm asking if it's possible to rotate the crank backwards and create slack in the timing chain causing the valves to hit piston
  4. Aug 16, 2015 at 1:46 AM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    If your timing chain has enough slack to make that a problem, you have bigger things to worry about.... Your engine should hold remarkably well in first gear.
  5. Aug 16, 2015 at 1:54 AM
    bicks
    bicks [OP] Member
    john
    Sydney Australia
    Hilux 2.7 2wd
    soon
    Just that I heard somewhere that the tensioner can become slack as it is only meant to go one way
  6. Aug 16, 2015 at 6:17 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Leave it in reverse and it won't turn backwards, if it turns at all.
    And get your Ebrake fixed ;)
    mistermanny and MGtaco2.7 like this.
  7. Aug 17, 2015 at 12:56 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine did roll away a few times while parked in 1st with no e brake. Didn't hurt anything that I could tell, although I was amazed that it actually rolled.
  8. Aug 17, 2015 at 1:52 PM
    bicks
    bicks [OP] Member
    john
    Sydney Australia
    Hilux 2.7 2wd
    soon
    Did roll backwards in 1st and was it the old 3rz or the new 2tr-fe, not sure if the old engine was a interference type.
  9. Aug 17, 2015 at 1:55 PM
    MowTaco
    Kansas
    2RZ (so pretty close to the 3RZ), I believe it was an interference engine. Yes it was in 1st gear, it would roll on that specific driveway in 1st or reverse.
  10. Aug 17, 2015 at 1:57 PM
    bicks
    bicks [OP] Member
    john
    Sydney Australia
    Hilux 2.7 2wd
    soon
    Good to know it didn't damage anything.
  11. Aug 17, 2015 at 2:02 PM
    bicks
    bicks [OP] Member
    john
    Sydney Australia
    Hilux 2.7 2wd
    soon
    Mine still seems to be running ok, no noise on cold start up, but I will def leave in reverse next time and fix e-brake. :thumbsup:
  12. Aug 17, 2015 at 2:16 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Oh ok! Lol. I didn't understand your question.
    So just ignore me. :)
    bicks[QUOTED][OP] likes this.
