Engine Damage or Transmission?
Discussion in '1st Gen. Tacomas (1995-2004)' started by LukeCC, Apr 25, 2019.
  1. May 22, 2019 at 3:33 PM
    LukeCC
    LukeCC [OP] Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    Thank you sir :rofl:
  2. May 22, 2019 at 3:36 PM
    Glamisman
    Glamisman Well-Known Member
    re read your initial issue and rather than me explain one possibility here is the link https://www.roadrunnerconverters.com/what-is-torque-converter-shudder/. Pay special attention to the diagnosis with the brake pedal applied idea.
    the other thing that comes to mind and this is a long shot is that the rubber check balls in the valve body are shot.
    LukeCC[OP] likes this.
  3. May 22, 2019 at 3:44 PM
    LukeCC
    Luke
    2002 LT DCSB
    The symptoms described for TC shudder is definitely not consistent with the “surging” that I’m experiencing. Mine isn’t doing a quick shake like running over a cattle guard. It’s surging. It can last up to 5 seconds.
    Another good thing is the symptoms to fix it such as transmission rebuild and ATF flush or refill will all take place from the time I dropped it to when I reinstall it this weekend. Hopefully all goes well. Thanks!
  4. May 22, 2019 at 11:07 PM
    Glamisman
    I did a little more googling and changed some of the "search words"... one thing came back that I found interesting, the site mentioned if the TPS is slightly out of adjustment the trans will hunt at various times for the correct gear... maybe, just maybe when you lawn darted her the TPS was jarred.
    TheGoat and MunchTIME like this.
  5. May 22, 2019 at 11:20 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Check for a bent frame also.
  6. May 23, 2019 at 6:37 AM
    LukeCC
    Luke
    2002 LT DCSB
    hmmm. interesting. ill have to check the tps and make sure its sitting happily. its a long shot but i'm not ruling anything out. thanks. :thumbsup:
    MunchTIME likes this.
  7. May 23, 2019 at 6:39 AM
    LukeCC
    Luke
    2002 LT DCSB
    after i got back from the trip i did a once over and the frame seemed to be straight. dented the shit out of the bumper but the frame seemed good
  8. May 24, 2019 at 11:25 AM
    eeoor88
    eeoor88 Member
    Larry
    2015 sport
    cap
    Long time reader but i had to register. I have had sort of the same problem. Try getting a new battery you may have damaged yours in your landing. Took a truck to transmission man years ago i was sure trani was junk, not shifting correctly,doing lots of different things at different times. All i needed was a new battery,old battery would start truck but did not have enough juice to run computer the way it should run,
  9. May 24, 2019 at 11:38 AM
    eeoor88
    eeoor88 Member
    Larry
    2015 sport
    cap
    Don't just check the battery get a new one. The cheapest place to start
    BassAckwards likes this.
  10. May 24, 2019 at 11:40 AM
    eon_blue
    Azusa, CA
    Even in the rear where the bump stops are? I remember a thread on here where a 2nd gen hit a rut at 35mph and buckled the rear of his frame where it made contact with his bump stops, he even had Superbumps on at the time.
    His bed was loaded with a lot of weight though.
  11. May 24, 2019 at 11:42 AM
    eeoor88
    eeoor88 Member
    Larry
    2015 sport
    cap
    Years ago we trashed batteries with hole shots at the drag strip. Your landing was a lot harder than any of our hole shots
  12. May 24, 2019 at 11:45 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    If it were changing gears you would have seen rpm go up or down more or less than cruise rpm.
    This really sounded more throttle related than transmission.
  13. May 24, 2019 at 12:28 PM
    LukeCC
    Luke
    2002 LT DCSB
    Interesting. I might try that. Thanks man
  14. May 24, 2019 at 12:29 PM
    LukeCC
    Luke
    2002 LT DCSB
    Yeah. Front to back. Frame was good
    eon_blue[QUOTED] likes this.
  15. May 24, 2019 at 12:37 PM
    #35
    MunchTIME
    MunchTIME Well-Known Member
    SD, CA
    Anytime i've had surging it's been intake related from the throttle body to an intake leak past the MAF sensor. Check TPS, and intake to the TB for leaks or anything partially or fully disconnected. not trying to give you random suggestions, just trying to help you catch the goose you're chasing.
    cruxofthebisquit likes this.
  16. May 24, 2019 at 12:41 PM
    #36
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    Check electrical, like stated about the battery. Put a voltmeter on it and check the alternator too. Hold the rpms at about 2k or so see if it's putting out good voltage.
  17. May 24, 2019 at 1:44 PM
    #37
    cruxofthebisquit
    Orange Texas
    2000 TRD
    did you take the intake apart to clean out the sand?
  18. May 24, 2019 at 9:51 PM
    #38
    LukeCC
    Luke
    2002 LT DCSB
    I appreciate it. I recently dealt with some emission issues. Replaced o2 sensors And switched back to box filter from Cai to smog. Still surging. Replaced tps last year for a cel
  19. May 24, 2019 at 9:52 PM
    #39
    LukeCC
    Luke
    2002 LT DCSB
    Idk if this was a question for me or him but in the event it was for me yes, I always clean cai after desert trips
  20. May 24, 2019 at 9:55 PM
    #40
    LukeCC
    Luke
    2002 LT DCSB
    Definitely going to look into the battery thing after I get the transmission installed if the problem persists
