Engine died while driving - oil light came on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Waborat, Jan 28, 2024.
  1. Jan 29, 2024 at 5:17 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I would say you need to investigate replacing your cam sensor if you got that code and are experiencing shutdowns.
  2. Jan 29, 2024 at 5:26 PM
    Waasheem
    Waasheem
    2007 xrunner
    Was it this bad?
    Marc70 likes this.
  3. Jan 29, 2024 at 5:38 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The engine won't run if the various cam/crank position sensors aren't communicating. P0345 is an open or short in the bank 2 (driver's side) VVT sensor circuit. You can unplug the sensor and do a basic voltage check, but if that doesn't show an exceedance, you will need a lab scope to diagnose it completely.
  4. Jan 29, 2024 at 8:22 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    No. It is a variable reluctor that reads the magnetic signature oe the steel vanes passing by on the cam wheel. While a large collection of ferrous shavings stuck to the sensor can cause issues, nothing non ferrous like oil or coolant can mess it up.
  5. Jan 29, 2024 at 8:45 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Marc70 likes this.
  6. Jan 29, 2024 at 8:58 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    If the CEL was a P0345, then replacing the CPS with an OEM one would be the route I would take.
  7. Jan 29, 2024 at 9:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Everything looks different and worse AFTER a problem occurs.
    You need a scan tool.
    CVCV likes this.
