Engine Dies When Coming To A Stop
Discussion in 'General Automotive' started by Drunknsloth, May 15, 2011.
  1. May 15, 2011 at 1:07 PM
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    So my friend has an '01 Honda CR-V and had the engine rebuilt, but now it's starting to die randomly sometimes when it comes to a stop and sometimes it just won't start. What do you think is the problem?
  2. May 15, 2011 at 4:35 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Start at the cheap and work toward expensive. Do a vaccum, fuel pressure, exhaust back backpressure, and spark test. By doing these tests, you will narrow down the list of suspects. Right now... The list is very long.
  3. May 15, 2011 at 7:46 PM
    Drunknsloth
    Retribution
    South West
    That's what I figured, just seeing if anything has a higher chance of being the culprit. The thing that's confusing me though is that the Check Engine Light isn't even on.
    Yep, it's an automatic, might have to look into that.
  4. May 15, 2011 at 7:50 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Might want to also check the distributor (I think it has one? :notsure:). Honda's are notorious for those going bad.
  5. May 15, 2011 at 7:54 PM
    Drunknsloth
    Retribution
    South West
    That's a good idea, but wouldn't it randomly die whenever? Not just when coming to a stop or not starting?
  6. May 15, 2011 at 7:57 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    What he said.
  7. May 15, 2011 at 7:58 PM
    NelsonTacoma
    Tucson, AZ
    Possibly. But when diagnosing an intermittent problem you should consider all possibilities. Honestly the distributor would be the last thing to try since they are very expensive.
    I work in a used car department at a local dealership. I see these Hondas come through all the time and at least half of them have a new distributor, cap, rotor, & wires on them..... just my .02
  8. May 16, 2011 at 6:22 AM
    Drunknsloth
    Retribution
    South West
    Sounds good, thanks man
  9. May 16, 2011 at 6:38 AM
    Tckwarrior
    Tckwarrior Well-Known Member
    Aaron
    Damascus OR
    08 RegCab Superwhite
    3 inch revtek lift,American Eagle 197 Black Wheels 17x9 Boltpattern 6x5.5 , 285/70/17's with BFG km2s U-haul class 3 tow hitch, Better built toolbox. Trail-gear 58 inch Rock-sliders
    Fuel pump
  10. May 16, 2011 at 7:03 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Check for a Vacuum leak first. The EGR gasket is a common place for vacuum leaks. The easiest way to test is to spray carb & choke cleaner at various spots where you think it might be leaking and it you hear a slight change in revs (carb cleaner being combusted) That's where your leak is.
    Change the cap and rotor...might as well and they're cheap. < $30 and replace the plugs while you're at it. I wouldn't worry about the wires. It's very rare for OEM Honda plug wires to go bad.
    Remove the IACV and clean it out with some carb and choke cleaner (replace gasket when doing so)
    Remove the EGR valve clean it with carb and choke cleaner (replace the gasket also)
  11. May 16, 2011 at 10:44 AM
    Drunknsloth
    Retribution
    South West
    Might have to do this when I have time this weekend
  12. May 16, 2011 at 11:06 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the spark plugs are tight. :eek:
  13. May 16, 2011 at 12:06 PM
    Drunknsloth
    Retribution
    South West
    I thought about all these but is there a reason that it is only dieing when it's coming to a stop? If it was something to do with the spark plugs or the igniting of the fuel wouldn't it die randomly at anytime? From the way my friend described it, I'm assuming the engine stalled, but it's an automatic. And sometimes it just won't start
  14. May 16, 2011 at 12:12 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    i would first check and clean the screen in the IACV.when it wont start does it have spark or no fuel?
  15. May 16, 2011 at 12:15 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2. I had an old car that would quit at a stop light unless you took it out of gear (automatic). Turned out to be a solenoid in the transmission. If you put it in neutral and glide to a stop, would it still stall out? That same car I had also had issues with the ECU, it would randomly shut off for no reason. We got rid of it because it wasn't worth the issues. You problem could be much simplier, hard to diagnose over the internet...
  16. May 16, 2011 at 12:21 PM
    Drunknsloth
    Retribution
    South West
    Good idea. Thanks man
  17. May 16, 2011 at 12:22 PM
    Drunknsloth
    Retribution
    South West
    I'll try putting it in neutral. Thanks. I'm just trying to get a few ideas :eek:
  18. May 16, 2011 at 12:26 PM
    macgyver
    Brad
    Canton, GA
    You could have M&M's in the gas tank...maybe one gets lodged in the fuel rail when coming to a stop then unblocks once you start moving forward.
    I know it's a stretch...but anything is possible.
  19. May 16, 2011 at 12:27 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    if the screen is clogged that will make it die at idle only.if the motor is shutting off and not starting back up,something else is going on.first check for spark(with a spark plug checker)sometimes they can fire across a plug but not be hot enough to run.
  20. May 16, 2011 at 12:30 PM
    Drunknsloth
    Retribution
    South West
    So true. Haha
    Sounds good, I'll check it out
