Engine dies when in neutral
Discussion in '1st Gen. Tacomas (1995-2004)' started by shrugg, Sep 16, 2009.
  1. Sep 16, 2009 at 7:00 PM
    shrugg
    shrugg [OP] Member
    NorCal
    TRD 4x4
    Gibson Exhaust
    My supercharged V6 2001 Tacoma won't idle, it just dies. I have to continuously rev the gas and keep the RPM's up or it quits! Needless to say I really hate traffic and stopping of any kind. If anyone out there knows what's up, please let me know what to do cuz I'm stumped...
  2. Sep 16, 2009 at 7:05 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    well several things. check the choke setting if its a throttle cable deal that might be it.
    it could also be a fuel filter deal check that.
    it could also be that your supercharger is not getting enough fuel to kep it ideling. so you might need to get a fuel control device that can re map your air to fuel ratios.
  3. Sep 16, 2009 at 7:16 PM
    shrugg
    shrugg [OP] Member
    NorCal
    TRD 4x4
    Gibson Exhaust
    What about a 7th injector kit?
  4. Sep 16, 2009 at 7:19 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    sounds very much like the idle air control valve (iac valve)
  5. Sep 16, 2009 at 7:20 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    OP do you have the 5vz-fe engine? 3.4 litre?
  6. Sep 16, 2009 at 7:27 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    a 7th injector kit form URD would most likely solve that problem. your probly running way to rich on your fuel mixture and that may be why your truck is stalling out and dieing
  7. Sep 16, 2009 at 8:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Check to make sure the vacuum line to the bypass valve is connected propperly, and not cracked.
  8. Sep 16, 2009 at 8:11 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  9. Sep 16, 2009 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cool:
  10. Sep 16, 2009 at 8:25 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Auto or manual?
  11. Sep 17, 2009 at 2:12 PM
    shrugg
    shrugg [OP] Member
    NorCal
    TRD 4x4
    Gibson Exhaust
    its the 5vz.fe 3.4 ltr and its a manual...is it hard to fix or clean the idle air control valve
  12. Sep 17, 2009 at 2:20 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  13. Sep 17, 2009 at 2:43 PM
    shrugg
    shrugg [OP] Member
    NorCal
    TRD 4x4
    Gibson Exhaust
    The light is on but its been on since I installed the supercharger...so years. Thanks for the diagram, I'll check it out and estimate the hassle value of removing my throttle body.
  14. Sep 17, 2009 at 2:51 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Wow! Get the code read. We could probably solve this issue in a few minutes.
  15. Sep 17, 2009 at 4:06 PM
    shrugg
    shrugg [OP] Member
    NorCal
    TRD 4x4
    Gibson Exhaust
    I've had the code read multiple times over the years and it's always the same...PC lean bank 1
  16. Sep 17, 2009 at 6:47 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    x2
  17. Sep 17, 2009 at 8:28 PM
    shrugg
    shrugg [OP] Member
    NorCal
    TRD 4x4
    Gibson Exhaust
    I checked all the hoses...all good and connected. I did seem to temporarily kinda fix it by messing around with the throttle cable. It's still doesn't sound real healthy but I can drive it...
  18. Sep 17, 2009 at 11:24 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I don't know much about supercharged trucks, but does it still have an EGR valve ? They're a little notorious for that kind of shit....:cool:
  19. Sep 18, 2009 at 8:16 AM
    shrugg
    shrugg [OP] Member
    NorCal
    TRD 4x4
    Gibson Exhaust
    It's times like these that I wish I woulda taken auto shop instead of wood...What's an EGR valve and where underthe hood can I find it?
  20. Sep 18, 2009 at 8:25 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You can't. The 5VZ doesn't have one. (Exhaust Gas Recirculatory Valve)
