Engine dies while driving...
Discussion in '1st Gen. Tacomas (1995-2004)' started by BugOutlaw, Apr 10, 2015.
  1. Apr 10, 2015 at 11:13 AM
    BugOutlaw
    BugOutlaw [OP] New Member
    Hey guys/gals. First off, I did search this topic, and there were a few hits but nothing substantive, so if I missed a Sticky or Topic point, just let me know.
    I have a 2004 PreRunner, V6, and yesterday, had it completely die on me twice while out to lunch. Both times it happened while either rolling to a stop, or sitting at a red light. Cranks right up just fine. All the lights flash when it dies, but nothing stays on, ie Check Engine.
    I had it towed to a shop and waiting on them to call, but thought I would throw it out there if someone had the same issue occur.
    Haven't had any work done lately other than an oil change (two weeks ago), but I did fill up the tank 10 minutes before the first fail. Maybe drove less than a mile when it died. So something with that?? Won't be the first time I got bad gas, :). And no, I didn't put diesel in the engine.
    Thanks in advance.
  2. Apr 10, 2015 at 11:16 AM
    lanestaco
    lanestaco Well-Known Member
    Lane
    Guthrie, OK
    '13 Tacoma TRD Sport 4x4
    Possibly bad gas? Sounds like it would be fuel related.
  3. Apr 10, 2015 at 11:17 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Also may be alternator related.
  4. Apr 10, 2015 at 1:20 PM
    lanestaco
    Lane
    Guthrie, OK
    Even though no lights are staying on, can you take it somewhere (O'Reilly's or AutoZone) and have them scan for codes thrown?
  5. Apr 11, 2015 at 8:55 AM
    BugOutlaw
    Ok, Update: lanestaco, did get it towed to AAA service center and they couldn't find anything wrong with it. No codes, nothing. However they did replicate the issue when they took it out. And besides them trying to fix things that may not need fixing, they just said, come and get it, we give up, lol. They didn't charge me thank God. Took it to a different place who I am more familiar with and they are going to try to determine what it is. Verdict is still out, but they think it could be something in the ignition. Maybe the key is backing out and the truck's computer is thinking I'm turning it off, hence no code. Bad gas has been ruled out.
  6. Apr 11, 2015 at 8:56 AM
    BugOutlaw
    PS. I did give them a few ideas generated from you guys (alternator, MAF sensor, fuel pump, etc). So THANK YOU!!
  7. Apr 20, 2015 at 10:21 AM
    lanestaco
    Lane
    Guthrie, OK
    You ever get this fixed?
  8. Apr 26, 2015 at 11:34 AM
    Ragtag98
    Ragtag98 Member
    Tristian
    98 PreRunner
    My truck had the same problem. Does it shake a little before it dies? It might be that its just stalling. I put new spark plugs in and a new ignition coil in and i was set.
  9. Apr 26, 2015 at 7:32 PM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Similar situation happened to me, turned out to be a loose ground on the diagnostic port to the intake manifold. Put Locktite Blue on the bolt that holds the ground wire to the manifold, tightened it up and the problem went away.
