Engine Dimensions 3.5L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cybrnitro, Mar 1, 2022.
  1. Mar 1, 2022 at 10:43 AM
    cybrnitro
    cybrnitro [OP] Well-Known Member
    Joshua
    Maine
    1939 International D2
    All of the RUST
    Looking for the Width, length, Height of the Stock Engine.
    Thanks
  2. Mar 1, 2022 at 10:46 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    210.9 cu. in.
  3. Mar 1, 2022 at 10:56 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Wrong subfourm.
  4. Mar 1, 2022 at 11:13 AM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Own a tape measure?
  5. Mar 1, 2022 at 11:19 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    If this is for your rat rod project with a 2nd gen Taco... are you looking for the 4.0L dimensions?
    Key-Rei likes this.
  6. Mar 9, 2022 at 1:36 AM
    cybrnitro
    Joshua
    Maine
    All of the RUST
    Yes it is for that. I found some frame dimensions. I’m all good. I should have measured it before I sold the 2016. I may be going towards a 1st gen tho now. Weighing my options. I have some time while I’m waiting for the cummins to show up.
    the distance between shock towers is my biggest issue right now! I don’t want the entire thing sitting outside the hood.
  7. Mar 9, 2022 at 9:56 PM
    TacoTuesday1
    SD CA
    LS swap
  8. Mar 9, 2022 at 10:27 PM
    cybrnitro
    Joshua
    Maine
    All of the RUST
    I wouldn’t do an ls swap. It’s getting a cummins.
  9. Mar 9, 2022 at 10:52 PM
    TacoTuesday1
    SD CA
    even better
