Engine Done
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SuperTaco66, Aug 13, 2022.
  1. Aug 13, 2022 at 3:31 PM
    SuperTaco66
    SuperTaco66 [OP] Member
    2016 TRD OR
    2016 Tacoma 85,000 miles and the engine has a tapping issue. Toyota recommends and engine break down and rebuild at $10k or a used engine with 44,000 miles for about same price. Bought vehicle used from a BMW dealership in 2018 and purchased a warranty with it. Always done oil changes myself so it might be a problem as I have no receipts for the filters, oil, and mileage records. Change it when the light comes on and keep getting it. It runs but the tap is there. Run it till it dies is an option, but it might cost more if I do that. Any suggestions?? Any reputable sources for a used or new engine? Can I even buy a brand new 3.5 for the Tacoma? Thanks for your help.
    Taco Tyrant and Superdave1.0 like this.
  2. Aug 13, 2022 at 3:44 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 TRD Off Road Bronze Oxide
    Dang, sorry to hear about that. Depending how handy you are you might consider a good junk yard engine and swap it yourself.
    shakerhood and Mully like this.
  3. Aug 13, 2022 at 3:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you choose the used engine route, you might as well run it until it quits.
    I suppose a rebuild is an option. But I can’t image the labor on that.
    Surely you can find a good used engine for less. Maybe try some place other than the dealership to swap it?
    ToyoTaco25, shakerhood, Mully and 2 others like this.
  4. Aug 13, 2022 at 3:49 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Junkyard engine will run $2000-$3000 depending on where you are. Check your local Craigslist, they show up there often.
    shakerhood likes this.
  5. Aug 13, 2022 at 3:50 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Pickeledpigsfeet and AJKlug1 like this.
  6. Aug 13, 2022 at 3:50 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    It's amazing how these threads come in waves. Been quite a few in the last few weeks.
    cryptolime, AxisCab, SR-71A and 4 others like this.
  7. Aug 13, 2022 at 3:50 PM
    Superdave1.0
    SoCal
    3rd gen Tacomas are getting up there in mileage. Get ready for more.
  8. Aug 13, 2022 at 3:53 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    My thoughts exactly.
    TnShooter[QUOTED] likes this.
  9. Aug 13, 2022 at 3:56 PM
    TnShooter
    Deogee
    STOCK
    I was expecting you to show up sooner or later. :rofl:
    I honestly don’t know what’s going on.
    I wasn’t around when the 4.0 first came out and had issues. But it seems like we’ve seen more 3.5 issues than usual lately. Weird. And not all of them are post “pandemic”. I can understand 2020. 2021 have issues. I mean, basically everything shut down and QC went down hill.
    But Pre 2020 trucks. You think would be solid?
  10. Aug 13, 2022 at 3:56 PM
    GarrettTacoma
    GarrettTacoma Well-Known Member
    2022 2.7L SR DCSB 2022 TRD OR DCLB
  11. Aug 13, 2022 at 3:57 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Sorry this happened to you.
    Is this a light tap from the top end or a heavy knock from the bottom or something else?
    Did anyone do any diagnostic work like checking the oil pressure?
    If it comes to a replacement I would search out a good used engine swapped by a reputable independent shop - not the dealership.
    Engines are out there, people crash these trucks everyday.
  12. Aug 13, 2022 at 4:37 PM
    HV101
    HV101 Well-Known Member
    Harlow
    2016 Gray Tacoma SR5 Access Cab
    None
    This is good advice. When does this tap occur? Idle? Normal driving? Did it develop suddenly or has it been going on for awhile? Besides the tap, is engine running ok? No fault codes? Exhaust system ok? Oil consumption/color/pressure normal? Cooling system/belts ok? Check spark plugs, compression, valves?
    A tapping sound could come from several causes. A good mechanic can sometimes isolate the source and it might be fixed. Sometimes a stethoscope can isolate the source of an engine noise. If a Toyota dealer suggested you replace the engine, I hope they gave you a diagnosis. And that would probably tell you whether or not an engine change is urgent. You should definitely get a second opinion.
    If the engine is going south, I wouldn’t chance getting stranded. For a 6 or 7 year old truck, I would be looking for a low mileage, used engine. Good luck and hope it works out for you.
    auskip07 and RustyGreen[QUOTED] like this.
  13. Aug 13, 2022 at 5:03 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    these same type threads are coming fast and furious! this might be it for for me for Toyota next go around.
    that go around might be sooner than later.
    Superdave1.0 likes this.
  14. Aug 13, 2022 at 5:05 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    Think the 2nd gens will out last the 3rd gens.
    Auzea, AJKlug1, Mully and 1 other person like this.
  15. Aug 13, 2022 at 5:18 PM
    GBR
    GBR Well-Known Member
    19 TRD OR
    Personal views on ethics aside...
    Your best bet from a financial perspective is to trade it in while it still runs.
    2wdSR52022, Camel89, Vmax540 and 2 others like this.
  16. Aug 13, 2022 at 5:19 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    how is running it till it dies a more expensive option? besides the tow to a shop and then source a replacement from there. i would run it
  17. Aug 13, 2022 at 5:22 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Ok, I’ll address the elephant in the room. The last three engine problem posters had a total of 7, 21, and 14 posts respectively. These engine problems aren’t occurring to engines of longer standing members. Just saying….
    CGPickup, GF8er, JmsWms and 15 others like this.
  18. Aug 13, 2022 at 5:24 PM
    Superdave1.0
    SoCal
    For a 3rd gen Tacoma, that's up there. 1st and 2nd gen Tacoma that's just getting broken in. My opinion, not fact, mate.
    Mully likes this.
  19. Aug 13, 2022 at 5:24 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    :tinfoilhat::tinfoilhat:
  20. Aug 13, 2022 at 5:25 PM
    Toyko Joe
    Just saw a 3rd gen with 750,000 miles on the high mileage thread. 85k is almost 1/10.
