Engine Electric Cooling Fan Assembly for 3rd gen tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tape, Jul 11, 2019.
  1. Jul 11, 2019 at 7:17 PM
    Tape
    Tape [OP] Well-Known Member
    Tape
    2019 Super White OR
    I'm sure it's been talked about but search function returns "trans cooling" subjects.
    Is there an electric cooling fan swap out we can do or are we stuck with the direct drive fan?
    Does anyone know the CFM our factory fan pushes?
  2. Jul 11, 2019 at 7:51 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I believe there is a TSB that adds an Electric Fan in addition to the normal fan to improve AC performance.
    Flash1034 and Tape[OP] like this.
  3. Jul 11, 2019 at 8:03 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    You can add an electrical fan...you would need a “puller style” with ac relay. Measure your existing fan shroud get that size or slightly smaller. I plan on doing this just haven’t gotten around to it yet. Jegs, Summit, EBay or Amazon would have one just no direct bolt in plug and play replacements that I’m aware of at this time. Probably pick up a few ponies and engine will rev quicker with less parasitic drag.
    Big tall dave and Tape[OP] like this.
  4. Jul 11, 2019 at 9:13 PM
    Tape
    Tape
    2019 Super White OR
    I'm tired of hearing the fan rev up so quick, it seems as if the motor is straining.
  5. Jul 11, 2019 at 9:18 PM
    Bishop84
    Bishop84 Well-Known Member
    It is straining, but it's reliable. I changed lots of fan clutches on domestics but have yet to on any 96+ Toyota.
    The problem is you mess with engineering, the shroud is designed with a mechanical pull fan in mind. The direct drive fan is ideal because it speeds up with engine load, something that an electric fan can do, but adds complexity.
    I would never delete a mechanical fan unless there was a fail safe designed to alert me of failure.
    hiPSI, Dirty Harry, auskip07 and 4 others like this.
  6. Jul 11, 2019 at 10:05 PM
    crx7
    crx7 1997 FZJ80 Triple Locked
    Grand Junction Colorado
    The mechanical fan is better than any electric fan you could fab up. You can really hear your fan? I can't hear mine.
    hiPSI, Boghog1, specter208 and 2 others like this.
  7. Jul 11, 2019 at 10:19 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    I have a manual trans and I actually like the noise of the fan when I rev up.. it reminds me of the sound of the old fj60 and fj70 with in-line 6.
    It makes me feel that I am in an older truck.. or just connected to the older models.. heritage feeling..
    It might sound like BS but is how I feel...
    Another reason I love my TOYOTA truck. It might be induced by movies like back to the future or toy story (I’m 31 YO) but anyways, I like it.
  8. Jul 11, 2019 at 10:21 PM
    crx7
    I guess I'm not revving enough :(
    Boghog1 and davidstacoma like this.
  9. Jul 11, 2019 at 10:39 PM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    What’s the objective OP? Busy work or something else?
    Boghog1 and Chew like this.
  10. Jul 12, 2019 at 5:42 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Sounds like it!
    Boghog1 likes this.
  11. Jul 12, 2019 at 5:48 AM
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    I want to add a electric fan to increase airflow across the a/c condenser when the truck is not moving and the rpms of the clutch fan are low.
    Dirty Harry and shakerhood like this.
  12. Jul 12, 2019 at 5:48 AM
    Phil
    Florida
    16 TRD OR 4Door 6MT
    This
    shakerhood[QUOTED] likes this.
  13. Jul 12, 2019 at 6:52 AM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    My fan clutch went out on my '96 Tacoma at around 210k miles. Lasted a long time. One cold morning I realized my engine was abnormally quiet at start up haha At least they are very easy to change out.
  14. Jul 12, 2019 at 7:34 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Look at other Toyota/Lexus vehicles for design ideas and capacities. The fans from a Sienna w/ the 2GR-FKS might be enough. Up the efficiency of the system with degas/expansion tank. Might want a larger alternator and battery to keep up with energy demands.
    AKGSD likes this.
  15. Jul 12, 2019 at 6:40 PM
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Switching to an electric radiator fan will do nothing for this. The drag you're feeling is from the horsepower used to turn the A/C compressor.
    specter208 likes this.
  16. Jul 12, 2019 at 6:56 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    This truck does not use a mechanical direct drive fan. It uses a viscous fan clutch that is setup to provide sufficient cooling. It will not turn on until the clutch assembly heats up to 210-220°F.
  17. Jul 13, 2019 at 8:42 AM
    specter208
    California
    The viscous fan clutch is one of the best and reliable methods to cool the radiator and use the least HP possible.
  18. Jul 13, 2019 at 1:29 PM
    specter208
    California
    The fan clutch goes full blast when it hits probably 210-220°F. Below those temps, the fan is basically freewheeling but they can be setup to come on sooner at lower temps, or too have a little more drag at idle and colder temps.
    2001 4x4 and skyking3 like this.
  19. Jul 13, 2019 at 2:22 PM
    BearWithMe
    Four Corners
    Prior: '18 OR 6MT
    The fan clutch has, I think, a fairly gradual engagement as temps rise. The A/C clutch is a strict on/off so you really feel it engage/disengage. I think it's not very analogous.
    2001 4x4 likes this.
  20. Jul 13, 2019 at 10:54 PM
    Tape
    Tape
    2019 Super White OR
    The clutch fan is "Never" freewheeling. It is engaged as soon as the engine starts and is why you hear a high whirling sound and there is no temp setting, just open your hood and give it a turn, you can feel the resistance instantly.
