Engine Electric Cooling Fan Assembly for 3rd gen tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tape, Jul 11, 2019.
  1. Jul 14, 2019 at 6:42 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    The fan clutch in this truck is setup to provide a small amount of cooling at idle speed but the clutch is not a fully engaged at cold start temps or even at optimal engine temps on this truck which is around 190°F.
  2. Feb 6, 2020 at 12:02 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Isn’t that the point of a temp gauge? (Plus a truck of this era will definitely pop a warning on the dash if it gets too hot)
    Depends how hot it is. Driving around in Phoenix at 116, that fan is fully locked up — definitely consumes some horsepower —and the A/C output sucks
    that resistance when you pop the hood, on a cold engine anyway, is actually because the fluid settles when it cools off overnight - hence it being so noisy on cold starts for a bit.
    There is variance on it’s level of engagement, heat dependent, once the fluid starts to flow again.
    there’s definitely a HP and likely an MPG gain to be had going electric - after all, why else would every other marque be doing it?
    VB25 likes this.
  3. Feb 6, 2020 at 6:19 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    You are definitely going to need to upgrade your alternator, and do some creative wiring, if you plan on replacing your existing fan.
  4. Feb 6, 2020 at 8:49 PM
    AKGSD
    Joe
    Alaska
    Doubtful the factory charging system couldn’t handle the additional load
    i’ve run electric fans on older rigs (with less alternator output) with no issue
    Skydvrr likes this.
  5. Feb 6, 2020 at 8:58 PM
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    Wait...is the fan the higher-pitched mechanical whirring noise I hear that seems to have no direct connection to RPM or drivetrain load?
    I figured that was some sort of diff noise...
  6. Feb 6, 2020 at 9:03 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Sound alike diff noise. Fan sounds like it's moving air and definitely tied to rpm.
    vecdran[QUOTED] likes this.
  7. Feb 6, 2020 at 9:29 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    @Tape here is a video that will explain how the fan clutch works on the Tacoma.
    https://youtu.be/UwM4OqsLek4
    MDFM31, AKGSD and shakerhood like this.
  8. Feb 6, 2020 at 10:00 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    You won’t find an e fan that pulls as much air as the mechanical fan. You can put dual electric fans and get close to the cfm. But the gains are minimal. When the fan clutch isn’t hot enough it’s almost freewheeling. The initial start up when you start the truck is the clutch locked until the fluid spreads around after sitting. When it’s cold with the engine running you should be able to to stop it with rolled up newspaper
    the clutches are proven and reliable. I keep em on all my trucks.
    Chew likes this.
  9. Feb 7, 2020 at 11:00 AM
    AKGSD
    Joe
    Alaska
    I will say, i’ve had a “heavy duty fan clutch” that’s basically engaged all the time - on a 98 discovery - i lost 2mpg and the loss of power was noticeable - switching from aftermarket electric fans
    I think if you lived somewhere very hot like Phoenix you would notice a difference. I could feel the loss of power on my taco when it was fully locked at 116*F. Plus the A/C output /sucked/
  10. Feb 7, 2020 at 6:04 PM
    SubieRuby
    SubieRuby Well-Known Member
    kevin
    Northern VT
    19 Tacoma TRD Offroad
  11. Feb 7, 2020 at 6:12 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    An electric fan would have to be able to cool with the same capacity as the stock clutch fan and the power isn't free. It just moves from the water pump to the alternator. At 116°F and A/C use, loss of power would be equivalent to the mechanical fan. The only difference is the disconnect and mounting options available. The efficiency would be negligible, other wise Toyota would have installed one. Look what they did with the auto transmission for fuel economy.
    Chew and slander like this.
  12. Feb 7, 2020 at 6:21 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Has toyota quality really gone that far down the crapper or are 3rd gen owners that picky? Seriously?
    I can rock crawl my 3.4l 1st gen all day in 90+ degree heat with 90% humidity with the AC going full blast with no loss of cool air or the temp gauge moving from the middle. This is with the stock fan setup and the smallest 4cyl radiator toyota makes and most of the grill being blocked by a winch, skid plate and a huge power steering cooler.
    I agree with others there is no way I would ditch the stock mechanical fan setup for electric.
    Chew and VB25 like this.
  13. Feb 7, 2020 at 9:49 PM
    AKGSD
    Joe
    Alaska
    Efficiency isn’t the only thing Toyota would have been looking at.
    however, a good clue is the general industry trend towards electric fans - because you can get similar cooling, quieter running, smaller packaging - and yes, an mpg gain.
    The only rigs besides these tacos with a mechanical fan are the heavy duty pickups - and even those are electronically controlled.
    Yota is just a dinosaur on tech. Always has been
  14. Feb 8, 2020 at 6:49 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    E fans are more efficient and can provide full cfm at idle. There's a reason the AC tsb adds an efan. Efans have proven themselves to be plenty reliable Toyota just opted for the cheaper mechanical fan.
    AKGSD likes this.
  15. Feb 8, 2020 at 11:14 AM
    #35
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Yes, the shit you will read around here is astounding.
    Kaptain_02 and slander[QUOTED] like this.
  16. Jun 23, 2021 at 7:39 AM
    #36
    Trucken77
    Trucken77 Well-Known Member
    Texas
    2021 Toyota Tacoma TRD off road
    They “the dealership“ will not do it they will fight tooth and nail swear up-and-down that there is no TSB for it make you sit up there all day and waste your time
  17. Mar 6, 2023 at 5:16 PM
    #37
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Agree with you here 100%. :thumbsup: I had two mid-90's Volvo 245's and a 745 with mechanical viscous-clutch fans. They roared on start-up just like my Tacoma, and then quieted back down again after about 10 seconds: confirming to me they were working as expected. I put 300,000+ miles on all three of those cars and never had any issues or failures with the fans. Once in a while the conditions were right and they would spin-up with a roar; but it was rare. When I heard my son's 2005 do the same thing when he started it for the test drive, it brought a smile to my face... Volvo added an electric pusher fan to the 1993 Volvo's, but they kept the clutch fan behind the radiator. My cars never over-heated. They did it to improve the performance of the air conditioner and it only ran when you turned on the A/C as I recall. It worked. The 1990 a/c really struggled even on a 85 degree day. The 93 (R134) was always ice-cold in any conditions.
    My 2014 Taco roars every time I cold-start it, and it's music to my ears.:rolleyes:
