Engine Failure at 40K, Multiple Repair Attemps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GoyoGreybeard, Feb 15, 2021.
  1. Feb 16, 2021 at 10:22 AM
    #61
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    Info on California Lemon Law:
    https://www.youtube.com/watch?v=vpcUoiAHu94
  2. Feb 16, 2021 at 10:54 AM
    #62
    Wicker24
    Wicker24 Well-Known Member
    2018 TRD Off Road
    This is false. They are relatively easy to win if you are in the right and they cost exactly 0 dollars to go thru.
    therealprotaco and 5465 like this.
  3. Feb 16, 2021 at 12:54 PM
    #63
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    I want to know what the OP means by "broke down" again. And if the dealer has looked at the issue.
    eurowner likes this.
  4. Feb 16, 2021 at 1:06 PM
    #64
    CRSTRD
    CRSTRD Well-Known Member
    2020 Tacoma TRD Off Road
    Lemon Law must not be that hard, in some places. About 12 years ago, I bought a nearly new '07 VW GLI that was a buy-back car. I bought it because the issue was a broken timing chain and they replaced the engine....so it was virtually impossible that a dealer had attempted to fix the same issue 3x. Car only had 1,800 miles and was being sold at nearly 50% off new MSRP. I drove the car for 2 years, with no issues, and traded it for a 2011 Tacoma and I was happy with the trade offer. The dealer didn't seem to care about the branded title.
  5. Feb 16, 2021 at 1:20 PM
    #65
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    It varies by state. In some the manufacturer can drag it out by going to arbitration, then contesting that and stalling on a settlement. I read about a case where GM dragged a case out for 18 months even though they knew the truck was unrepairable. In that case the customer needed to hire a lawyer.
    shakerhood and Wicker24[QUOTED] like this.
  6. Feb 16, 2021 at 1:25 PM
    #66
    GoyoGreybeard
    GoyoGreybeard [OP] Well-Known Member
    Southern California
    2021 V6 4WD OR DCSB
    "broke-down" = stalled while driving. I haven't heard back from the dealership yet. Last I heard they are waiting for Toyota to analyze diagnostics and report back.
    tacotoe and MGMDesertTaco like this.
  7. Feb 17, 2021 at 12:18 PM
    #67
    GoyoGreybeard
    Southern California
    2021 V6 4WD OR DCSB
    UPDATE: Dealership said that that they found debris, possibly coolant moisture, on the injector wires. They said that the truck seems to be running fine now but they can't give it back to me because they need approval from Toyota, which is in Texas and currently has no power.
    ~The second time it broke-down, it would start, but stall immediately when put in gear
    What ya'll think?
  8. Feb 17, 2021 at 12:26 PM
    #68
    eurowner
    eurowner Duke Sky
    Scoty
    Go get it and drive it!
    Chew likes this.
  9. Feb 17, 2021 at 12:35 PM
    #69
    MGMDesertTaco
    I'd politely demand Toyota Corporate offer an extended warranty just so my butt was covered and I'd do it BEFORE taking possession of the truck and BEFORE returning any loaner vehicle if you have one. Tell them you've been inconvenienced and you want reassurance of their product. Then I'd look for a replacement vehicle when I had more time, preferably at another dealership and trade it in, but that's just me.
    They're not explaining why there was debris possibly coolant moisture on the injector wires or how it happened. They need to be specific of the problem/solution and it sounds like they're teaming up with corporate to provide you with the same answer or explanation.
  10. Feb 17, 2021 at 3:28 PM
    #70
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I think it sounds like you've got a truck with a sporadic problem that hasn't been fixed.
    Debris, possibly coolant moisture on some wires? If that's not a shot in the dark diagnosis, I don't know what is.
    If that's all they're willing to give, it'd be with a heavy heart that I drove that truck off their lot.
  11. Feb 18, 2021 at 5:32 AM
    #71
    rolled93slc
    Jerry
    Lynchburg VA
    I have had that happen to me when reassembling an engine. Had some coolant in a connector that I didn't see when installing the harness. So it's a very possible situation. Every engine I rebuild, and I have done several for issue close to this (valves not sealing to seat, usually and exhaust valve on bank 1 on the 2Gr FSK), I drive them for a minimum of 30 miles.
    Pickeledpigsfeet and T-yoda like this.
  12. Feb 20, 2021 at 7:41 PM
    #72
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    ' Lemon Laws ‘ state to stay vary widely
    those im familiar with dont apply here
    always worth a try
    when the engine failed the OP should have been Informed
    what went wrong ....................what broke & why !!!
    No less decisions by dealer & owner are made at that juncture
    the owner doesnt dictate what he thinks ‘ Should ‘ be done to rectify the situation
    no less the dealer doesnt start repair be it repair or replacement
    iv read this several times still wonder why/how engine failed at a nominal mileage
  13. Feb 20, 2021 at 8:18 PM
    #73
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    Forsure I would lemon that bitch for a new one in army green
    The hammer likes this.
  14. Feb 20, 2021 at 8:43 PM
    #74
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Ask for a direct replacement truck,you shouldn't have too be taking time out too run down to Toyota everytime the truck breaks down.
    The dealership already proved time and again they cant fix your current truck.
  15. Feb 20, 2021 at 8:47 PM
    #75
    Mtnfly
    Mtnfly Member
    2018 Toyota Tacoma TRD OFF-ROAD Double Cab 4x4
    Same thing happened to mine. 40k. Service dept immediately replaced the entire engine. Sent it to Toyota to study what happened. Put another 35k on it since then without any problems.
  16. Feb 21, 2021 at 8:45 AM
    #76
    MGMDesertTaco
    I'm curious, did y'all change your oil at Toyota's recommend intervals or sooner like 3k miles? Any aftermarket parts like intakes/ air filters? I know someone who bought a VW Jetta new many years ago, followed VW's 10k oil change intervals and had major engine/ timing change problems at around 54K miles. VW said it shouldn't have happened and repaired it for free.
    I've only read about a few of these Toyota's with major engine failure at less than 40k and I'm thinking it probably had to do with something during the engine assembly process. Especially, since Toyota really ramped up Tacoma production numbers after 2017 to meet consumer demand. :confused:
    Another thought, I think the 3.5 is also used in the Lexus RX350. I haven't heard of Lexus having any issues with their engines, ever. :confused:
  17. Feb 21, 2021 at 8:53 AM
    #77
    Mtnfly
    Mtnfly Member
  18. Feb 21, 2021 at 8:57 AM
    #78
    Mtnfly
    Mtnfly Member
    I had my truck serviced every 5k at the dealer. Nothing aftermarket. 100% TRD OFF ROAD. 2018. Gentle driver. No off-roading. Drove it to Canada 2 months prior to breaking. NevEr had any suspicion something was wrong....driving home from Costco. Car trembled for like 5 seconds, thought I had a flat, then every light on the dash lit up like a Christmas Tree. Then stalled out....never to start again.
    MGMDesertTaco likes this.
  19. Feb 21, 2021 at 10:37 AM
    #79
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    You're in CA and if I recall correctly, you're already qualifying for a lemon law. I would start that conversation with Toyota sooner vs later.
  20. Feb 21, 2021 at 11:00 AM
    #80
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    As soon as a lawyer gets involved
    Toyota will stop all work on the vehicle
    until the case is resolved
    HisDad, Kev250R and shakerhood like this.
