Engine fan questions after front end damage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2G taco guy, Jun 18, 2025 at 10:28 AM.
  1. Jun 18, 2025 at 10:28 AM
    2G taco guy
    2G taco guy [OP] Member
    George
    Ct
    2006, 4.0l,4wd, manual transmission, sr5 access cab, w/tow package
    Nothing major. As of spring 2025 I’m currently trying to repair damage from minor collision
    I have a couple questions concerning engine vibration on my truck that happens after warm-up. i’m currently trying to fix some minor damage from a front end collision mostly to the front and passenger side. The truck starts up and drives perfectly fine and obviously starts to run hot (need radiator) after I warm it up and let it idle. I know there can be several reasons for this from engine mounts to many other things but a friend of mine pointed out it could be the engine fan which is missing a blade at the moment and says when the clutch engages It can likely caused the vibration which is not terrible but very noticeable. I’m just curious if that is possibly the cause which I am going to diagnose and dive into later today. Currently not driving it just trying to diagnose this particular issue move onto the next. And as far as everything else the truck drives, shifts (manual trans), and power steering as well as everything else not associated with the coolant system is fine. No check engine lights either. I’m mainly curious if the Fan clutch assembly or possibly the fan itself can cause the type of vibration that you feel in cab and transmission you can see vibrating But engine and transmission mounts are fine. that’s what makes me wonder if it’s fan itself or possibly the fan clutch. I will see if the fan spins freely or has any resistance which will give me an idea if it’s the fan clutch and I will also be removing the serpentine belt to see if no vibration once up to temperature. Sorry for long post, talk to text, and wanted to cover what I know is or isn’t wrong so far.
  2. Jun 18, 2025 at 10:31 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    yes, 100% a missing blade will cause a moderate noticable vibration
    koditten and 2G taco guy[OP] like this.
  3. Jun 18, 2025 at 10:36 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Take a blade off you ceiling fan and see if it vibrates. Fix it sooner than later, you’re stressing out the bearings in and water pump.
  4. Jun 18, 2025 at 10:40 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    You are going to start destroying things pretty quickly. I once lost a fan blade on a 72 Land cruiser on a trip and I cut the opposite one off to equal the imbalance. Worked well enough to get me thru about 600 miles of driving and a couple days off road. No way would I have been able to get away with 3 blades, the vibration was pretty bad. I'd bet it's worse then you think on yours.
    2G taco guy[OP] likes this.
  5. Jun 18, 2025 at 10:44 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Already been running warm and low on coolant...:popcorn:
    SR-71A and TnShooter like this.
  6. Jun 18, 2025 at 10:53 AM
    2G taco guy
    George
    Ct
    Same thing my friend was telling me but I was only asking if it’s possibly the clutch because it doesn’t vibrate until the truck is warmed up. And I think you are replying to my post. Or that’s a weird coincidence. Sorry I’m new to this forum.
    ABA180 likes this.
  7. Jun 18, 2025 at 11:04 AM
    2G taco guy
    George
    Ct
    Yes obviously I know the low coolant is a big issue. Especially since my post said I need to replace the radiator. I was just trying to narrow down the cause of the vibration before I dump money into stuff when it could be something completely different causing the problem. And no-show here so you can put the popcorn away obviously a coolant leak will call something to run hot But I don’t ever have to worry about it overheating because I don’t run it that long just wanted to see how everything ran when it was up to temperature and I noticed the vibration and being there is a fan blade missing I figured it’s likely something related to that because the motor mounts appear to be fine and it doesn’t do it when it’s cold
    ABA180 likes this.
  8. Jun 18, 2025 at 11:20 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The radiator core support is a weak design on these trucks.
    I’d inspect/replace it before I went to put it back together.
    And I’m with the others, sounds like the fan to me.
    HondaGM and 2G taco guy[OP] like this.
  9. Jun 18, 2025 at 11:20 AM
    2G taco guy
    George
    Ct
    Oh I am very aware of the bad things that can happen. And I’m not driving it as we speak I’m just trying to diagnose issues because I need to get it back on the road. But I’m going to do some diagnostics later and thank you because you confirmed my suspicion
  10. Jun 18, 2025 at 11:22 AM
    2G taco guy
    George
    Ct
    Yes thank you. I was just trying to narrow down the cause of the vibration. Just wanted to double check especially since it only does it after warm-up
    HondaGM likes this.
  11. Jun 18, 2025 at 11:22 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Fluid "viscous" clutches like these trucks have engage more when warm. Less when cold. Possible the fan isn't spinning quite fast enough when cool
    You need a new fan.
  12. Jun 18, 2025 at 11:28 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I'm thinking the same re the fan. Ran into this on an old car I had, I forget what it was but same fix.
    Good luck and welcome!
  13. Jun 18, 2025 at 12:34 PM
    Chuy
    Lakeside, CA
    Silver Taco
    The fan clutch has a thermo sensor, it will lock the fan at specified temps and rpm’s. The fan will always rotate as long as the fan clutch rotates, but it only locks up at certain points, that’s when you feel the vibrations the strongest.
  14. Jun 18, 2025 at 12:52 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    The fan is separate from the clutch on these trucks. Go buy another fan before your fan comes apart and you need a new radiator and more parts.
    Jimmyh, 2G taco guy[OP] and HondaGM like this.
  15. Jun 18, 2025 at 1:18 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Why not remove the broken fan assembly entirely?
    Reinstall the hold down nuts to keep the pulley in place.
    You will need to stack a few washers since the stud threads are not threaded enough to tighten the pulley.
    Start the truck and see if you get the vibration when it starts to warm up.
    You will now have verification that unbalanced fan is your culprit.
    2G taco guy[OP], TomTwo and HondaGM like this.
  16. Jun 18, 2025 at 1:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    you know you need a new fan regardless of if it's the cause or not
    Do that and see what happens.
    Do the radiator you know you need while you are in there
    2G taco guy[OP] and koditten like this.
  17. Jun 19, 2025 at 9:41 AM
    2G taco guy
    George
    Ct
    If you were going to buy a radiator support to replace the factory one is there any particular brand you would suggest or is something from rock auto good enough? Damage is to passenger side. And I don’t wanna have to wrestle with bent metal and have to worry about my alignment issues with headlights, etc
  18. Jun 19, 2025 at 9:42 AM
    2G taco guy
    George
    Ct
    I already need new parts. And I’m getting a new fan as well I just wanted to Confirm that was the issue
    TomTwo[QUOTED] likes this.
  19. Jun 19, 2025 at 9:43 AM
    2G taco guy
    George
    Ct
    Yep that’s the plan as well as new radiator support and air conditioning condenser. thanks
  20. Jun 19, 2025 at 9:45 AM
    2G taco guy
    George
    Ct
    Yeah I didn’t get around to it yesterday but I was also just thinking of maybe removing the serpentine belt and letting it run for a couple minutes to look it’s up to temp. I know I have to be careful with that obviously but it all has to come apart anyway
