Engine Fan Removal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Slinky, Aug 22, 2016.
  1. Aug 22, 2016 at 1:40 AM
    Slinky
    Slinky [OP] Whatchu talkin bout willis?
    Spencer
    San Diego, CA
    2004 Tacoma
    Flowmaster 40 series muffler, Doug Thorley Headerd, MTX RTS10-04 10" sub, Boss Audio R1100M amp, Viper 3305V Alarm, 22" Digi-Diodes LED bar mounted on custom bumper, Camburg Long Travel up front with Fox 8" coilovers and 600# Eibach Coils 07-14-16
    Had an idea in my mind, just curious how crazy it is. Would it be reasonable or possible to remove the fan from your motor, keeping the pulley, just removing the fan, and putting in electric fans on your radiator relayed to a switch?
    Just figured I'd bring the idea to some others to get some real feedback.
  2. Aug 22, 2016 at 4:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's not a crazy idea at all. Many people have done it. Personally, I don't think it's worth the investment.
  3. Aug 22, 2016 at 5:12 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Reasonable, I dont know. Possible, yes. What would you be trying to accomplish by going that route? That'll help us define if it's reasonable or not.
  4. Aug 22, 2016 at 6:08 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    If you do make sure it comes on with air conditioner compressor
  5. Aug 22, 2016 at 9:38 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Is there something wrong with the OEM fan? If so, why not just fix it (or do you have money to throw away at your truck)?
  6. Aug 24, 2016 at 8:17 PM
    Slinky
    Spencer
    San Diego, CA
    2004 Tacoma
    No reason for trying it. Just wondering is it risky? Is it more or less efficient than the stock fan?
  7. Aug 24, 2016 at 8:43 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I did it on my 78 2wd. It wasn't worth it, the electric fan was not as good at cooling as the factory fan then the electric fan failed. I put the factory fan back on. Maybe on a race car that moved at speed most of the time this would be a good idea but not on a street vehicle or 4wd that needs cooling while moving slowly in my experience. I had to turn the heater on full when the truck started to overheat on a hot day in traffic.
  8. Aug 24, 2016 at 8:51 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I did it on my 91. I wouldn't do it again. It did cool very well and looked sharp but was very loud by comparison. Also incurred a very high current draw so that my headlights would dim whenever it kicked on. Didn't see any gain in mpg or power.
  9. Aug 24, 2016 at 11:44 PM
    eon_blue
    Azusa, CA
    That's the exact setup I have. Dual Flex a Lite electric fans, controlled by a switch inside the cab. I leave it "on" at all times for obvious reasons as I don't want my truck to overheat, so I think the manual switch idea is dumb (previous owner installed it).
    Plus, when I'm off-roading in 4lo for extended periods of time on inclines I start to overheat. E-fans don't do so great at cooling in high RPM/low speed circumstances, they are better for performance applications. Going back to the stock fan clutch is on my list of to-do mods.
  10. Aug 24, 2016 at 11:46 PM
    eon_blue
    Azusa, CA
    This too! My e-fans are loud as hell (even though Flex a Lite advertises them as "quieter" than the stock fan clutch :rolleyes:) and my lights dim real low if I so much as lightly feather my clutch, and my power windows slow wayyy down when I work both at the same time. I always wondered why that happened lol, makes sense that the e-fans are drawing all the power. Thanks!
  11. Aug 25, 2016 at 11:46 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Keep the stock fan and clutch. Electric fans would be a step backwards from a reliability standpoint.
  12. Aug 27, 2016 at 12:11 AM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    Ill be the odd one out and say Efan was one of the best power gain mods ive done to my 2rz and Ive done everything short of boost or cams at this point.
    Fans are a little louder but doesnt bother me, my truck isnt quiet in any way. I run the Flex-a-lite dual fan set for the specific vehicle not a universal. Couldnt be happier. Granted I do run dual Optimas and the biggest Mean Green alternator made for the 2rz.
    Oh and I used to have on an autoswitch but went manual a number of years ago and never have had an issue.
