Engine having issues.
Discussion in 'Technical Chat' started by oregon01, Nov 8, 2012.
  1. Nov 8, 2012 at 1:50 PM
    oregon01
    oregon01 [OP] Member
    oregon
    01 prerunner 3.4 stock
    Stock
    2001 tacoma 3.4 prerunner 4 door. Runs good most of the time. No lack of power, no check engine light.
    Problem= Very intermittent rough idle or sputter that sometimes leads to the engine dying at idle or as applying the gas from idle, Plugs white as if running lean, poor poor gas mileage. I am talking like 10-12 mpg and its not due to my foot
    Attempts to correct= New plugs and wires, new air filter, fuel system cleaner.
    What next?
  2. Nov 8, 2012 at 2:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check the vacuum lines
  3. Nov 8, 2012 at 6:49 PM
    oregon01
    oregon
    Stock
    Done. Being as it is so intermittent I figured it was not a vacuum issue but I checked anyways
  4. Nov 8, 2012 at 6:54 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    Clean the MAFI as well, but white plugs show a lean condition.
    I would look for a vac leak as well, seems like you have un metered air.
    I have seen the vac line to the brake booster crack a few times on the 3.4L
    Also check for cracks in the intake pipe after the MAF
    Justin
  5. Nov 8, 2012 at 7:35 PM
    oregon01
    oregon
    Stock
    I did check for vac leaks and I just took off the intake tube and it is good. I also just cleaned the maf. We will see if that does the trick. I had a 01 ranger and it got a vac leak at the booster. Never knew till i ran a stoplight with my brake pedal on the floor. Anyways I am leaning toward a sensor. just not sure what one
  6. Feb 26, 2013 at 11:39 AM
    mltitlntd
    mltitlntd Well-Known Member
    Steven
    New Orleans, La
    99 Tacoma 3.4 V6 4WD SR5
    None
    Any follow up on this? I am having a similar issue. Thanks!
  7. Feb 26, 2013 at 3:14 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Check the idle air control valve. could be gunked up and sticking
  8. Feb 26, 2013 at 3:17 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    EGR valve.
  9. Feb 26, 2013 at 4:22 PM
    mltitlntd
    Steven
    New Orleans, La
    None
    Buzz and Steve. I know the idle air control valve. Would that tend to stick open or closed? Never id'd the egr valve. My truck used to start with an authoritative roar. Now it struggles to start.
  10. Feb 26, 2013 at 4:57 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    There may be an opening under the EGR valve to stick your finger and push up on the diaphram. It should move freely. If it doesn't use a none petroleum based solvent (it wont destroy the rubber diaphram) to spray underneath up into the valve to free it up. Or just replace the valve. The valve doesn't last forever and is cheap to replace.
  11. Feb 26, 2013 at 5:33 PM
    mltitlntd
    Steven
    New Orleans, La
    None
    I plan to change the oil tomorrow. Oh how I love dropping the skid-plate for that ;) I'll have a look at the egr valve. Hmmm... Decided to look around before posting this reply, since I've never seen it, and I don't usually miss much. Not sure I have one:
  12. Feb 26, 2013 at 5:35 PM
    mltitlntd
    Steven
    New Orleans, La
    None
    Oh... No Check Engine light, BTW, and I do have a 3.4L
