Engine hesitates on acceleration?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GasTiresOil, Jul 16, 2011.
  1. Jul 17, 2011 at 9:20 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Just because your plugs, fuel, and air filter are new, doesn't mean they are good. Just gonna toss that one out there.
    When you put your plugs in, did you put dielectric on them? Did you check gapping? Are they screwed in tight, and not crossthreaded (bad day), what plugs did you use? Try resetting your coil packs maybe, check their connections.
  2. Jul 17, 2011 at 12:12 PM
    medic2230
    Murph
    Bama! Roll Tide
    I know the toyota platinum plugs made mine skip. How in the hell do you reset the coil packs?
  3. Jul 17, 2011 at 2:21 PM
    brian
    Elizabeth City, NC
    Sorry, think I missed a letter, I meant re-seat them. Pull them off the plug and put em back on making sure they're on good. Also verify the connector to the coil packs are on tight.
  4. Jul 17, 2011 at 2:59 PM
    GasTiresOil
    GasTiresOil [OP] Glockin
    11 Tundra RW
    Definitely a noticable stutter. I unhooked the battery, left it 10 mins and hooked it back up. After driving around today about 40 miles round trip it is much worse now.
    First is the idle. it idles at approx. 550rom then the idle drops and goes back up to normal idle. It does not surge past what seems like the normal idle.
    Second is acceleration. Just normal driving from a dead stop the truck stutters as I'm giving it gas. It finally evens out as I slowly build speed and the rpms get around 3k.
    And third is during normal cruising. I keep the shifter in 4 so the tranny isnt hunting back and forth when driving around town, If I"m on the highway or gonna be at speeds over 50mph I kick the shifter over to D. If i put the shifter into overdrive the rpm's of course drop because the truck shifts. As I'm cruising in overdrive if I give it just a little gas it starts stuttering and then it downshifts and the rpm's bump up and the stuttering is not as bad. It seems to be worse with low and high rpms.
    Just when I think I have it figured out as to when its going to happen, I'm cruising at 40mph, shifter in 4, and it stutters for like a second and then its fine again.
    It's definitely worse at lower rpm. I'm thinking maybe the MAF is dirty or took a dump for some reason? Maybe the TPS is shot? IDK. And to address the spark plug question, I put in Autolite XP iridium plugs, gapped, and dielectric greased.
    Sorry for the long post, I'm trying to explain this as best I can. Thank you for all your replies.
  5. Jul 17, 2011 at 4:43 PM
    medic2230
    Murph
    Bama! Roll Tide
    Mine is doing that too but I've got a 1st gen. I changed the TPS and it didn't make a difference. Changed plugs that did help a little but still doing it. I haven't messed with the MAF or fuel filter though. Mine could be completely different though cause I'm right at 200,000 miles. I'm kinda lost too with this whole thing. I'll be watching to see if you get it figured out. If I figure it out I'll let you know what to try.
  6. Jul 18, 2011 at 8:24 AM
    GasTiresOil
    11 Tundra RW
    The truck went to the shop today. We'll see how this turns out. Of course im 3 months past warranty....
  7. Jul 28, 2011 at 7:38 PM
    deejayehn
    deejayehn New Member
    98 Toyota Tacoma 2.4l 2wd
    I have the same problem...did you find out what it was?
  8. Aug 5, 2011 at 6:30 PM
    GasTiresOil
    11 Tundra RW
    I did find out what it was. The autolite xp plugs overheated and the porcelin cracked. Replaced with Toyota plugs and all is well.
    And I no longer own the taco. I traded it for an 11 tundra rock warrior. The dealer gave me 20k for the taco so I was pretty happy about that. I will be posting up several items for sale soon.
  9. Aug 5, 2011 at 6:38 PM
    brian
    Elizabeth City, NC
    Score one for this guy. <<. I was right for once... haha. Glad you got it fixed, even though you now own a Tundra...sounds like fun :)
  10. Sep 30, 2015 at 7:33 AM
    WhiteTacomaTRD
    WhiteTacomaTRD Member
    Ricky
    2006 Tacoma Double Cab 4WD TRD 4.0L
    Your problem with hesitation on acceleration was the spark plugs? I just changed mine about a year ago and I just changed the MAF sensor two weeks ago. I've been having the same hesitation on acceleration problem with my '06 4WD 4.0L. I'm trying to figure out what the heck is going on. Thanks!
