Engine Hesitation
Discussion in '1st Gen. Tacomas (1995-2004)' started by RPain, Aug 4, 2011.
  1. Aug 4, 2011 at 3:00 PM
    RPain
    RPain [OP] Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    My current problem is while I'm driving i will have my foot on the gas then suddenly the engine will stop accelerating completely for about 2 seconds at a time. It happens most requently right after the engine is turned on but still occurs after that.
    Only thing I have done to the truck recently was I switched over to synthetic oil. I thought the issue could do with the fact that I didn't get another oil change right away but I got an oil change today and the problem still persists. Any input or help will be much appreciated. Hopefully and inexpensive fix im sick of this money shit... :mad:
  2. Aug 4, 2011 at 3:02 PM
    mx04taco
    mx04taco Well-Known Member
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    Flowmaster exhaust, Pioneer DVD HU, Pioneer speakers all around, , Viper security w/ remote start, Tinted Windows, Silverstar Headlights, Toytec 3" Coil Springs, All Pro Offroad Diff Drop 3/4", Bilstein 5100s, 2" Toytec AAL's, Toytec poly rear leaf bushings, Deckplate Mod 4", 265/75r16 firestone destination a/t's
    have you checked the plugs? where do you buy gas?
  3. Aug 4, 2011 at 3:04 PM
    RPain
    Chandler, Arizona
    I was sort of leaning towards checking the plugs too. Currently on a tank of chevron gas but the problem started on a tank of arco...
  4. Aug 4, 2011 at 3:05 PM
    mx04taco
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    do you know how long its been since the plugs were changed?
  5. Aug 4, 2011 at 3:10 PM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like the TPS possibly
  6. Aug 4, 2011 at 3:13 PM
    RPain
    Chandler, Arizona
    I got new plugs only ~15k miles ago I'm currently at 112k.
    Care to tell me more about the TPS?
  7. Aug 4, 2011 at 3:18 PM
    98tacoma27
    Ben
    Not Beech Creek
  8. Aug 4, 2011 at 3:32 PM
    RPain
    Chandler, Arizona
  9. Aug 4, 2011 at 3:34 PM
    mx04taco
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    well since your plugs are that young and im assuming you dont have a check engine light than you prob arent experiencing misfires. Could be a dead spot in your tps.
  10. Aug 4, 2011 at 3:36 PM
    RPain
    Chandler, Arizona
    Yeah no misfires or CEL. I get off work in 30 minutes so I'll let you all know how it works pumping the pedal 100 times
  11. Aug 4, 2011 at 3:44 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    I was having similar problems a few months ago. A new TPS and a good cleaning of the throttle body fixed the problem.
  12. Aug 4, 2011 at 4:31 PM
    swdockter
    swdockter Well-Known Member
    Northwest Burbs, IL
    2" lift, 5100s, AAL, K&N, Deck Plate, 375K and counting
    what he said. Take the time to remove the air intake components off and TB and clean it well.
  13. Aug 5, 2011 at 7:25 AM
    RPain
    Chandler, Arizona
    Going to clean my engine this weekend. 100 pumps worked as a temp fix but id like to make sure everything is prestine under the hood
