Engine hesitation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Drtierra, Mar 8, 2010.
  1. Mar 8, 2010 at 11:42 AM
    Drtierra
    Drtierra [OP] Member
    Az
    PreRunnner
    I am new on the forum but I know my problem is not.
    Have 2004 tacoma V 6 with a bad hesitation problem after it warms up. Prior to warm up it runs fine.
    The CEL came on last week. Took it to Pep Boys. Code indicated # 4 plug had problem. Checked pulg & found it was not tightened correctly. Fixed it. Truck ran better.
    Few days later hesitation began again.
    I have changed the fuel filter & plugs. CEL is on again. I will take it back to P B but wondered if any of you can help.
  2. Mar 8, 2010 at 1:02 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    clean the MAF sensor...
  3. Mar 9, 2010 at 12:45 PM
    Drtierra
    Az
    PreRunnner
    Thanks Mike. I did that but there is no change. It really wasnt dirty but I used MAF cleaner & Q tips.
    I suppose next is the 02 sensor. I will take it to have the code read & go from there.
  4. Mar 11, 2010 at 11:20 AM
    Drtierra
    Az
    PreRunnner
    Pep Boys checked code & says its a # 4 cylinder misfire. They want 90 bucks to tell me exactly what that means.
    I just put in new plugs. Could this be the plug wires? How do I check them?
    Or could this be something else that you know of?
    Thanks for any help.
  5. Mar 11, 2010 at 1:54 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I hope when you were cleaning your MAF you didnt touch the little wires with the q-tips! That would be verry bad!
    And It could possible the wires are bad, I would change them first. Then go from there. I cant remember which side #4 is on. But if it the coil pack side, I know that those can fail or go bad too. Just throughin things out there! Hope you find the problem man! :)
  6. Mar 13, 2010 at 5:14 PM
    Drtierra
    Az
    PreRunnner
    I think I found & fixed the problem today. Changed the # 4 plug wire. Unhooked battery to re-set CEL.
    Took truck for test drive for about 10 miles. Hesitation is gone. Engine runs as normal again.
    Thanks EverTaco for the tip.
