engine idle problems .
Discussion in '1st Gen. Tacomas (1995-2004)' started by pats02tacoma, Dec 25, 2011.
  1. Dec 25, 2011 at 4:49 PM
    pats02tacoma
    pats02tacoma [OP] New Member
    Pat
    California
    02 sr5 extracab v6
    while driving check engine light turned on, no serious issues until coming to a stop for awhile; then starts idle jumping from 700 to 1000 rpms. while traveling at higher speeds problem resolves. I am new to this have a few resolutions inside,but could really use other ideas if possible.
  2. Dec 25, 2011 at 6:07 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    What is the error code stored in the computer say?
    Sounds like you need to clean your maf and throttle body out. With that much rpm jump i would also be looking for vacuum leaks.
  3. Dec 25, 2011 at 6:13 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    ^^^^^^^^^^^^^ agree with this guy.
  4. Dec 25, 2011 at 8:45 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Find someone with a Scanguage or code reader
    and don't just guess at it.
  5. Dec 26, 2011 at 11:31 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    try cleaning out your IAC. they are notorious for getting gunked up and causing poor idle. it can get to the point where the truck will die at a stop light.
  6. Dec 26, 2011 at 5:29 PM
    pats02tacoma
    Pat
    California
    02 sr5 extracab v6
    my buddy hooked up his computer and found cylinder 5 was misfiring. time for a tune up. thanks yall.
