Engine/Intake Rattle during acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ikillterrorists, Nov 6, 2011.
  1. Nov 6, 2011 at 4:46 PM
    ikillterrorists
    ikillterrorists [OP] Well-Known Member
    Andrew
    New Paltz, NY
    Sold my tacoma, got a Dodge Ram
    TRD Cold air intake Aries Grille Guard Flowmaster American Thunder Dual Exhaust Pro comp 3" suspension lift KMC XD Hoss, BFG KM2 285/75/16 Hypertech Speedometer Calibrator N-Fab Side Steps Access Roll-Up Cover TRD Quick Shifter SafeHitch
    Hello everybody,
    I just noticed this today (I have 30k miles on my truck). There's a loud rattling that happens when I'm in 1st or 2nd gear, and going above 2k RPM. The rattling sounds like it's coming from the engine, maybe a little on the driver's side. I have a TRD CAI. I took a quick look under the hood and didn't seem see anything wrong.
    Also don't know if this could somehow be related, but yesterday the oil plug fell out and all my oil drained out while I was offroading. Idiot Toyota dealership mechs didn't tighten it enough.
    Any thoughts?
  2. Nov 6, 2011 at 4:54 PM
    Pannell_Trd
    Pannell_Trd Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    Mine has had a rattling noise for a while, i cant figure out what it is. Ive been told on here to check where the air intake goes into the fender and check the hood latch but i haven't been able to figure it out, Ive got used to the noise.
  3. Nov 6, 2011 at 4:59 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    :eek: WTF
  4. Nov 7, 2011 at 4:29 AM
    ikillterrorists
    Andrew
    New Paltz, NY
  5. Nov 7, 2011 at 4:43 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Do your own oil changes so you know its done correctly.
  6. Nov 7, 2011 at 4:24 PM
    ikillterrorists
    Andrew
    New Paltz, NY
    Yeah, and also did some more searching around, and seems like many people have developed this rattling noise too...
  7. Nov 7, 2011 at 8:21 PM
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    WTF?
    Your oil drained out while offroading?
    How long did you run the motor before you realized the oil had dumped on the ground?
  8. Nov 8, 2011 at 4:23 AM
    ikillterrorists
    Andrew
    New Paltz, NY
    Well I got back on the road, drove for like a mile or 2 until the oil light turned on and the engine shut down. I had no idea what was going on, so I kept turning the engine back on and trying to drive for like another quarter mile before I finally pulled over and figured it out. Hopefully the transmission is not ruined now...
  9. Nov 8, 2011 at 4:51 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I wouldn't be worried about the transmission, I'd be wondering when I'm getting a new engine!
  10. Nov 8, 2011 at 1:46 PM
    ikillterrorists
    Andrew
    New Paltz, NY
    Is this bad? After I put a new plug in and filled up the oil, I drove 130 miles back home...
  11. Nov 8, 2011 at 1:48 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    i had the same thing with my K&N. turns out the cone filter was barely vibrating on the fender making all the noise. tighten down all your bolts/screws on the CAI and make sure the filter isnt rubbing on anything.
  12. Nov 8, 2011 at 1:49 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yes this is bad. You ran your engine without oil, then it died and you proceeded to keep starting it and running it until it died again. Im surprised its still running.
  13. Nov 8, 2011 at 2:44 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    My redneck analysis, rod bearing is starving due to opened clearances.
    You'll know for sure over time. Only way to find is tear it down and rebuild it.
    I don't understand why so many don't get it... the oil light is the motor-is-already-dead light. You NEVER start it up after that. It only lights up after oil pressure drops below what the engine needs to survive. At least your truck kept going a while. It's even worse with 4 cyl Honda's, their lights come up at about 3 psi (because they make only about 5-10 psi at idle when warm), and the mains are toast by then.
  14. Nov 8, 2011 at 2:52 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I hope your joking. Yes it is really bad. As said above your motor is probably toast. I wouldnt tell the driving with no oil story when you take it in for a new engine
  15. Nov 8, 2011 at 5:00 PM
    Bosmob
    Kevin
    San Diego, CA
    OHHHHH!!
    You sir have most likely fried or severely damaged an internal part. I'm guessing that it is the rod bearings since it rattles during acceleration and that is when the motor is under the most load.
    You should have had some common sense and just called it quits the second that oil light came on.
    I suggest you go get that engine checked out!
  16. Nov 8, 2011 at 7:22 PM
    ikillterrorists
    Andrew
    New Paltz, NY
    Okay scheduled an appointment for saturday. But other than the rattle in 1st/2nd gear, everything else felt/sounded normal on the drive back home...
  17. Nov 8, 2011 at 7:43 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Well, your engine was more than likely damaged...if you concider that to be a problem I guess it could be a bad thing.
  18. Nov 8, 2011 at 8:34 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i have a rattle while the rpm's climb in first and second. id don't think it's where the intake goes through the fender however because i had removed all the stuff from behind there for my snorkel installation.
    the baffle or resonator thing gone the factory piping gone and the noise still persists. it sounds like a heat shield underneath to me but, they seem to be ok as well maybe its the flow master 40 series muffler as i have heard of people with this same rattling noise and it's actually coming from their muffler. just a thought
  19. Nov 8, 2011 at 9:27 PM
    ktmrider
    Junk
    The gravity of the situation is it is extremely likely you have caused permanent engine damage, so if you can blame the dealership and actually get them to acknowledge they did not torque the drain plug properly have them get you a new engine.
  20. Nov 8, 2011 at 9:35 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    its a toyota dude!:facepalm:
